125-200cc Lectron installed, I'm impressed
Discussion in '2 Stroke' started by Boosted Josh, Mar 6, 2014.
  1. Boosted Josh Husqvarna
    Birmingham, Alabama
    '14 CR125, '14 TE511
    BMW S1000RR
    After fighting with the jetting on my new 125 and reading all the great results everyone seems to be having with the Lectrons I sent Kelly an email and had one on the way.
    Install went easy, even though I didn't know what I was doing. Old one comes off along with 10lbs of vent hoses, switch the throttle cable into the Lectron, screw it back together, and put it in. There were some metal shavings/slivers that needed to be clean out of the Lectron before bolting it up, mostly on the notch on the slide where the throttle cable installs. No big deal but something to watch out for.
    Initial results are great! Installed right out of the box with ZERO adjustment and the bike fired up after 2 kicks. Idle was great (couldn't get the bike to idle worth a damn with the stock carb) and response is crisp off the bottom, it'll need maybe just a slight adjustment on top as it seems a little lean but I'm basing that on the sound not the feel. Needless to say I'm impressed, I can't believe how well the bike runs with no adjustment and I know with a little fine tuning it'll be even better. I decided to wait for any fine tuning until I put my new pipe and silencer on it.
    Pipe and silencer waiting to be installed.
  2. Motosportz CH Sponsor
    Nice glad you like it so far. We set them up erroring on the rich side so it probably needs leaned out some. You'll get a feel for it. On these carbs it is semi anti intuitive and needs leaner when it feels lean. You will sort it, no big deal.
    thats not good and I have not seen this before. Will address this with Lectron. There is a good bit of mods and machining to make them Motosportz spec and fit our bikes right and thats what that is about but should be perfectly clean when you get it.
    Kelly
    PineapplePicker likes this.
  3. flyingbob Administrator
    USA
    01&02WR360_02WR250_02CR250_12WB165
    01 VOR400_07 TM450_22 GG250_07 Tuono
    Radiator guards!!! A new bike just looks so nice!
  4. typeone Husqvarna
    central MA
    07 TC270 + 09 WR165
    08 X4 146 + 13 250RR
    nice! i love mine too but man am i jealous of that perfect air boot fit (i had to cut my boot).
    can we get the earlier version that was sold machined down to fit now?
  5. Lighterknot Husqvarna
    Vacaville, CA
    07 CR125
    12 KTM 500 EXC
    Any downside to using a lectron on a bike that is MX only? How much do they cost?
  6. Motosportz CH Sponsor
    No. $390 (shipped) all setup with custom metering rod, relocated, breathers, externally adjustable powerjet, machined to fit your bike and other Motosportz spec'ed changes. We have put a lot of effort into them to make them right for our applications.
  7. Motosportz CH Sponsor
    yes. But it is really hard after the fact. Carb has to be completely disassembled, jigged, machined and reassembled. Its a lot of work and they don't like doing it but will if you really need it (for a cost). These things evolve and we are constantly making changes and upgrades to make them better as we work with them. The cool thing is Lectron and Motosportz have a great relationship and stuff happens fast. Theres some new stuff coming for both carbs and EFI I cant talk about but are cool new solutions. Interesting stuff.
    typeone and troy deck like this.
  8. typeone Husqvarna
    central MA
    07 TC270 + 09 WR165
    makes sense, thanks for the reply!
    Motosportz likes this.
  9. 454x Husqvarna
    Dunnigan,Ca.
    2012 CR165 w/36mm lectron.
    Yes. I having I having mine shortened to better fit my new Beta 300RR next week.
    shawbagga and typeone like this.
  10. Rick Husqvarna
    Lodi, Ca
    99 GasGas EC 200 , 05 YZ 125
    So....the Lectron are now being made the same size as the 38mmTMXX? Like 92mm overall?
    Thanks
  11. Motosportz CH Sponsor
    Yes among many other changes we implemented.
  12. Rick Husqvarna
    Lodi, Ca
    Ok, that is nice to know......thanks Kelly.
  13. Hurky Husqvarna
    Spain
    WR300 2010
    Yamaha WR480F 2008
    Who sells these here in the forum ?
    I've a WR300 2010, just bought it and didn't try it really .. But I'm planning to get on of those Lectrons if I encounter carburation problems with the Mikuni... $390 is not cheap but the lack of carburation-needs and better mileage could justify it I think...
    I suppose they will be sent from the US ? I am in Spain so shipping and taxes make that thing even more expensive ...
    We will see what the first ride this sunday reveals ..
    Regards.
  14. mkfox Husqvarna
    Michigan
    2002 WR250
    1973 Greeves Griffon
    Motosportz (Kelley). You can also find info on his products in the Marketplace section on the front page. Super guy!
  15. R-J van Hulst Husqvarna
    Cambodia
    Honda CB 400 Vtec 3
    cheap or expensive is how you look at it
    I have a motorbike to ride and not to wrench, changing jets and needle settings on the trail can be done very quickly after numerous times of doing it (on a husky its a easy task, try do it on a 4 stroke honda your doomed :eek: ) but its a pain and not the idea of a ride that I have in mind.
    If I take all this time combined and simply put my hourly wage on top of it the $390 is a bargain, on top of that it does run more efficient with the fuel. consumption.
    I am not exaggerating but its putting the carb on the bike and it runs 95% good out of the box if you feel bothered by the last 5% its a simple task of max 10 minutes and you're set for the rest of the bikes life
    money well spend in my books.
    Robert-Jan
    Hurky, mkfox and Motosportz like this.
  16. NvRider55 Husqvarna
    N. Nv.
    2001 wr360
    KTM 525ex, 250xc 2T, 200sx,300mxc
    Running a 38 lectron for about a year on a 01 360, made my day.
    juicypips likes this.
  17. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    hey 454x what is the cost of machining it down? im thinking of either doing the same or selling off the one ive got for the newer machined down type. not a big issue I spose but don't like how the airbox gets deformed slightly & a tight fit with the original ones-im a little pedantic & like getting the newer improved versions of things:lol:
  18. Tim Randall Husqvarna
    NSW Australia
    Wr125 / WB165
    There is a local to me lectron for sale cheap that came off a husq 300. What adjustments would it need to suit a 01 125??
  19. Motosportz CH Sponsor
    MS3 rod. Will work with the rod that is in it but better with the right one.
  20. Tim Randall Husqvarna
    NSW Australia
    Wr125 / WB165
    What kind of $$ to get that in aus would I be looking at?
