Let me know if you want some. Rod is discounted to $32 and Tube is $9 (you can also cut yours for free if you wish) and about $3 for first class shipping in the USA as these are small parts. Email me if you want a set. Thanks Kelly
Thanks for sending the new rod and tube. I've installed the new rod at the same length as the standard 3-1 xl rod as a starring point. After removing the PJ adjustment screw, I thought that the PJ tube would come out easily. My tube appears to be stuck as it won't budge. Any suggestion or tips on how to remove this tube?
So this rod/tube richens up the mid and makes the carb meter fuel off the rod more so than the powervalve? I've spent quite a bit of time dialing in my lectron and am quite happy but get hesitation before pv engages. And when chopping wfo (doesn't bother me as much as the baw baw braap in mid range occasionally).
