125-200cc lectron or not...
Discussion in '2 Stroke' started by marshwater, Mar 4, 2013.
  1. marshwater Husqvarna
    WNC
    '12 TE449 (sold) '13 WB165
    having problems getting the minkuni carb sorted out on my 01 cr125. i ride elevations from 2200 - 5500. she won't idle. runs fine until it fouls a plug going down steep hills. what size main jet should i be running? any other tips or suggestions? if i go with the lectron, Will it solve my problems?
  2. Motosportz CH Sponsor
    sounds like your pilot jet is rich. No reason why you cant get the stock carb to jet within reason and run right without fouling. All that said, yes, the Lectron is EZ to setup and seems to just run prefect every time after that.
    Also as this is an older bike make sure everything else is good. Good compression (low compression fouls plugs and makes jetting hard), reeds are good, muffler is not plugged of dripping wet with 2 stroke oil, main seals are good... ETC.
    Vinduro and john01 like this.
  3. 454x Husqvarna
    Dunnigan,Ca.
    2012 CR165 w/36mm lectron.
    I VOTE LECTRON! YOU'LL LOVE IT.
    Vinduro and Jason S. like this.
  4. john01 Husqvarna
    Powhatan VA
    What Kelly (Motosportz) said. Check the other things first, re-jet if needed, then if you want get the Lectron. If it were me after checking the other stuff I'd just get the Lectron :D. Good Luck.
  5. rockdancer Husqvarna
    Sunshine Coast, Australia
    2013 WR125, 2019 FE350
    I am running a 380 main 27.5 pilot . You may want a slightly richer main than me - 400 - whats it got? Try screwing out air screw.
  6. Aviduser Husqvarna
    BC, Canada
    08 cr 165
    As a baseline my husky service manual says
    360 main for 5000'
    390 main for 2500' 30 pilot @ 10 c
    If your constantly going up and down in elevations you can jet it for an average. But it'll never be spot
    On it seems. If I get my bike running perfect then go up 1500' I have to change the plug by the time I'm back down as its too rich.
    Even though I ride at a consistent elevation mostly. Im still leaning towards the lectron. Even though u can get the tmx running good. You have to fiddle with it throughout the seasons of course.
  7. dirt-dude Husqvarna
    Pa.
    Both Of my 01's are running 25 pilot and 380 main one likes the needle in the 2nd notch from the top the other likes the 3rd, I run maxima k2
    @44:1 I've never had any jetting issues once they were sorted out, I have tons of hours on these things most of my riding is in the 1000
    to 2000 FT. range the fuel screw requires attention for temp. to keep it running crisp. If it used to run fine and you haven't changed oil
    brands or ratios start checking for a mechanical issue.
  8. marshwater Husqvarna
    WNC
    I often change between those elevations in 10 - 20 minutes. Western nc has some good local relief. I believe I changed the main to a 320. Don't want to have to fiddle around with carbs all day. does the lectron alleviate the elevation changes?
  9. Vinduro Husqvarna
    Mississippi
    Lectron, You won't regret.
    CelticDude likes this.
  10. sabortooth No Class
    Izard Co. Arkansas
    11uptite167
    Can you elaborate on your hard start issues at Sandlapper, whether it was electrical or fuel related?
  11. R_Little Husqvarna
    NJ
    Make sure your top end is fresh.
  12. marshwater Husqvarna
    WNC
    Has good compression. Run maxima50:1. Gas leaks out of carb when bike is stopped
  13. Motosportz CH Sponsor
    Float level is to high and/or your float needle is bad and passing fuel, both which could cause the jetting issues you are having.
  14. DTX915 Husqvarna
    wr125
    kdx200 tt500 yz450 klx125
    Ethanol eats your needle jet,distorts over time and leaks by. I have had more than one go bad. Unless you have a solid jet than float level or junk float.
  15. marshwater Husqvarna
    WNC
    The float needle had a grove on it. A new one is on order. Maybe the float is getting hung on it ?
  16. Motosportz CH Sponsor
    :thumbsup: sounds like you located the issue.
  17. Vinduro Husqvarna
    Mississippi
    I believe I will trace this to a bad ground on the ignition. I washed the bike Monday and the bike started first kick every time. The wash water completed the circuit. I bet now the bike is completely dry, it will be hard to start again.
  18. sabortooth No Class
    Izard Co. Arkansas
    11uptite167
    A gremlin like that can be aggrevating to say the least. I didn't think you would have anything bad to say about the lectron.
  19. marshwater Husqvarna
    WNC
    gonna pull the trigger on the lectron. going on a 01 cr125. should i get the 36 or 38? also, am i gonna have issues with the throttle cable?
  20. Parfo79 Husqvarna
    S Wales, UK
    '98/'05 CR125, '00 CR250
    many...
    Just ordered one from Motosportz :applause:
