LED blinkers installed on TE630 now no blinking. What relay is plug and play
Discussion in '610/630' started by sethro, Jan 13, 2012.
  1. sethro Husqvarna
    flagstaff AZ
    I just installed some really bright Baja Designs LED turn signals on the 630. I pretty much expected a fast flash rate but did not expect no flash at all. If you activate the turn signal switch the blinkers light up but don't blink.
    Does anyone know of a plug and play turn signal relay for the TE630?
    Thanks
    Sethro
  2. KLOC Husqvarna
    Edmonton, Alberta
  3. SilverBullet Husqvarna
    Harmaston, TX
    2011 TE630
  4. kingmoochr Husqvarna
    Any ELECTRONIC flasher relay should get them to work properly. Take yours to the local auto parts store and compare the plug with an available electronic flasher and you should be fine.
  5. sethro Husqvarna
    flagstaff AZ
    I just found the relay on the bike, it does not look like a normal relay, I will get a pic up here soon
    Sethro
  6. sethro Husqvarna
    flagstaff AZ
  7. SilverBullet Husqvarna
    Harmaston, TX
    2011 TE630
  8. sethro Husqvarna
    flagstaff AZ
    Just an update on the blinker flasher. It was a direct plug in and installed without any drama, works wonderful.
    I think my top speed is higher now also, :banana:
    Sethro
  9. awshouse Husqvarna
    Seattle
    I had a slightly different issue. Could use some advice.
    I installed the bajadesigns LED tail light on my 2008 TE 610. I then installed LED turn signals (rear & with a resistor). But when I did none of the turn signals worked (bike running). Then I went back to the original turn signals to determine whether it was perhaps the LED signals causing all signals to not work. I reinstalled the original turn signals, but still none of them work.
    Any thoughts on this? I checked the 5 fuses under the left and right cover. They are all good. And the signals definitely worked before I installed the LED tail light.
  10. Gnash Britches Husqvarna
    Sethro, was that the SICASS Smart Flasher that you ended up with, or something more generic?
  11. sethro Husqvarna
    flagstaff AZ
    Yes thats the one.
    Sethro
  12. larry belli Husqvarna
    Pittsburgh, Pa
    06 SM610
    09 Triumph Street Triple & HD XL883
    I do think the LED'S are polarity sensitive. Not positive, but worth a try.
  13. Osseous Husqvarna
    2011 TE630
    Super Tenere
    To be clear- do you need one of these LED compatible relays, or two? I'm doing front and rear turn signal conversion to LED
  14. RDTCU Husqvarna
    '11 630SMS
    There is only one flasher relay to replace.
  15. mjskier Husqvarna
    Northern Colorado
    2011 TE 630
    2012 KTM 990 SMT
    BTW, with a LED relay, my led turn signals work as expected, but the turn signal indicator doesn't blink (it does come on)
    Anybody else run into this? Not a bit deal, except that it makes it hard to realize you have been riding for miles with a blinker on :-)
  16. RDTCU Husqvarna
    '11 630SMS
    Same here. There's no pulsed feedback to the dash.
  17. tspoon Husqvarna
    Penticton BC
    TE 630
    XR 400
    Ditto, dash blinker does not flash.
  18. Osseous Husqvarna
    2011 TE630
    Super Tenere
    Anybody know where to get the quick connectors used on the stock te630 turn signals? I'd like to wire the LED blinkers with OEM male plugs to match the females that came on the bike.
  19. RDTCU Husqvarna
    '11 630SMS
    I just robbed them off of the factory indicators. A little tedious, but it works.
  20. Osseous Husqvarna
    2011 TE630
    Super Tenere
    Interesting- I was thinking that might be an option, but I hadn't dug one out of there to try that yet.
