LED Flasher Problem
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by pcross71, Sep 16, 2013.
  1. pcross71 Husqvarna
    New York
    Am having an odd problem with my LED blinker setup on a 2009 TE510. Installed HDB LED blinkers front and rear - as always, fantastic products from HDB. Of course, they blink fast on the stock flasher. Replaced with the HDB electronic flasher and now the LEDs are constant on (when directional switched on at the the bars) and a bit brighter during the normal flash cycle. So it looks like a surge where they're on, than even brighter for a moment, repeating. Timing of the brighter surge is the correct tempo (not fast). Paul kindly sent me a replacement flasher, same result.
    Separation of left and right is fine, but both have the problem (to be clear, when left directional switched on, the left front LED lights contstant, surges brighter on normal flash cycle, right is off as it should be - opposite for right side).
    I went back to the stock flasher and they cycle full on, full off, but fast.
    Connecting the wires directly (no flasher) results in constant on, normal brightness.
    Stock flasher and the replacement are both two wire electronic units.
    To try to isolate, I disconnected the rear LEDs. Same result.
    FYI have exact same setup on a 2008 TE450 and no issues.
    Any thoughts?
    Thanks
    Peter
  2. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
  3. pcross71 Husqvarna
    New York
    Thought I'd follow up with my solution in case other's have this problem. I ordered another type of electronic flasher with a built in ground lead from Amazon and it works perfectly (2 Terminal Turn Signal Flasher Switch For LED Lights / 12V / Electronic Switch). No idea why the standard two signal flasher from HDB didn't work on the TE510 but this was a simple fix. The bolt that holds the air box is perfect location for the ground lead.
    Peter
  4. Tinken Husqvarna
    Hesperia, CA
    MY12 WR511
    Yamaha
    I use a standard 3 wire from the auto parts store. It only uses one more additional ground, but when it goes out, you can always find them.
