LED Tail Light Install Help
Discussion in '4 Stroke' started by JSB Jeep, Sep 30, 2009.
  1. JSB Jeep Husqvarna
    Glendale, Az
    Hi all,
    I've tried the search feature but haven't found any kind of tutorial on an installation for an Edge-2 LED Tail Light Kit. My kit came in the mail today and I want to get going on the installation but I can't find any instructions. Any help would be much appreciated.
    Thanks!!
    2005 Husqvarna TE510
  2. HuskyDude Moderator
    BC, Canada
    13/TR650
    10/EC300, 76/TY175
    Hey JSB Jeep
    I'm sure someone will give you some direction soon. But in the meam time... if you use the search button at the top an type in "Wiring LED tail light" you will get lots of threads to read up on.
    here's two good ones to start with.
    Reload this Page LED turnsig/tail light replacement woes.......
    Brake light problem.
    Good Luck :thumbsup:
  3. Ruffus Husqvarna
    I just installed mine a couple weeks ago, if you can wait till later this evening, I'll find the wiring chart I wrote down, it's not like it seems it should be, took a little playing around with different combinations.
  4. Phoenix Husqvarna
    Oklahoma City, OK
    2009 TXC 450
    2 Ducs, 14 GG 200, 13 Husa 300
    I agree with Ruffus. The wires are backwards from what you think. I just used trial and error. If he doesn't find his, i'll unbolt my fender and write the wires down.
  5. glangston Husqvarna
    2012 Husqvarna TE 310
    2012 BETA 350 RS
    This is what I kept from a thread on installing a Baja Designs LED. This, I'm pretty sure is identical to the LED light that came in the powerup kits with the Arrow exhaust for 08's.
    If using the rear light that came with the power up kit it goes like this,,,,or this is what you'll need to get it all wired up. On the connector on the bike the wires go like this.....the red with the black stripe is the + for the right turn signal..... there is no black wire.... the blue wire is the ground for all the lights including the turn signals.....the lite blue is the + for the left turn signal....the yellow wire is for the running lights....and the green wire is for the brake light....
    Now for the light itself......the red wire is the brake light.....the black is the ground..... and the yellow is the running light..........this info is from an 08 TE450...
  6. Ruffus Husqvarna
    Okay, I checked mine
    Husky black to Edge black
    Husky yellow to Edge red
    Husky blue to Edge yellow
  7. JSB Jeep Husqvarna
    Glendale, Az
    Thanks everyone!!! This forum is loaded with some great people. I'm glad I chose a Husky.......
  8. xymotic Husqvarna
    Federal Way, WA
    Do you have any pictures of this light installed? Any reason it wouldn't fit a 610?
  9. JSB Jeep Husqvarna
    Glendale, Az
    No I haven't done this yet. I have yet to find a detailed write up for this particular application so I'm hoping to have a guy at work (nicknamed McGuyver) help me out. I'm hoping to get it done within the next week and can post pictures then if that helps. I don't see why it wouldn't work for your 610.
