Great forum guys. Best 610 info I have found on the net thus far. Two questions about the Leo Vince pipe: 1) What is the difference in performance, if any, between the full pipe setup and the slip-on? 2) Do both the full pipe and slip on options come with the Lambda sensor resistor plug-in and bung plug for the pipe? Many Thanks, Mike..
The difference in performance is between stock and the aftermarket pipes like the LV or Uptite is pretty amazing. My "seat of the pants" dyno says a good 3-4 hp increase. The difference between an LV slip-on and a full system is minimal and mostly only in the upper RPM range. As far as I know the LV system doesn't come with any hardware to eliminate the O2 sensor, I think that needs to be purchased separately.
I will second the above statement, even though I've never ridden with either system. I did a lot of research and internet searching when looking for a pipe for my 610 and this is what consistently showed up across the board. I'll let you know what the slip-on feels like very soon, as my sticky street tires are being put on right now as I type, and my new-to-me Leo Vince slip-on is going to be tested out for the first time today Whee!! WoodsChick
