Leo Vince
Discussion in '610/630' started by Nesbocaj, May 20, 2009.
  1. Nesbocaj Husqvarna
    Just got a LV :applause:
    It has 3 inserts and a screen. The screen I understand.:thumbsup:
    In looking at the inserts, I'm guessing that the angled one is the quiet one? And what are the other two?:excuseme:
    thanks!
    Bob
    OK, looked at the BACK side of the instructions, the short one is the quiet one, DOH!
  2. tosaw Husqvarna
    CT
    I just installed mine about a week or so ago and I was wishing I could read Italian lol
    I used the short one too because I wanted to use the spark arrester and it seemed that was the only one that would work with it.
    I noticed a modest power increase but I can't wait to install the PU resistor that I've had on order from Hall's since the 2nd of this month. Twice now they've taken more than 3 weeks to deliver my orders with no emails or contact of any kind. I'll really have to think hard before I order anything from them again. I wish I had ordered it from Kelly at Motosportz, he gets me parts in 1 week from across the country... sorry for getting off topic, enjoy the LV!
  3. glangston Husqvarna
    2012 Husqvarna TE 310
    2012 BETA 350 RS
    Keep in mind that George (Uptite Racing) makes 610 exhausts and they are rated pretty high by those who own them and test them.
  4. Nesbocaj Husqvarna
    I ordered the same item from Halls on 5/6, nothing yet either.
    Tomorrow I'll head over to Radio Shack and get a 45 cent resistor.:D
  5. Pics?
  6. glangston Husqvarna
    2012 BETA 350 RS
  7. tlking6 Husqvarna
    Vista, Ca
    I tried all three and didnt notice much of a difference. I am running the smaller diameter one with the tube that runs through the flange as it seemed to be the quietest. Still not quiet enough for my tastes. I did have to cut down the tube with a hacksaw about 3\4" to fit with the arrestor screen.
    I'm stashing away my pennies for one of these
    http://www.dirtwerkz.com/Merchant2/merchant.mvc?Screen=PROD&Product_Code=8002&Category_Code=260
    to try out. Some good reviews over on AdvRider
  8. rajobigguy Administrator
    So.Cal.
    I recently put a DB Dawg in my LV on my 610 and yes it is noticeably quieter with no appreciable reduction in performance but the way that it is held in with two set screws leave something to be desired. It's difficult to get the screws tight and they don't stay that way, if it weren't for the spark arrestor screen I'm pretty sure someone on the 605 frwy would have ended up with a DB Dawg in their windshield. I'm going to make a flange for the end of the LV that fits under the SA screen and weld the DB Dawg to it. I'll post some pics when it is done.
  9. Nesbocaj Husqvarna
    The shortest of the three is the quietest, and no sweat with the screen.
    The DB dawg just makes the exhaust make a last turn, tack weld a strip
    of steel on this short adapter cross-wise, and call it good.
  10. Reddog Husqvarna
    Michigan
    DB Dawg Warning
    I melted mine on a highway run today.
    Never turned the motor over 5700 RPM.
    Worked fine offroad, on road the heat got to it.
  11. Nesbocaj Husqvarna
    Frickin' amazing! What is it made out of?
    I did the aluminum strip restrictor as a test, works fine.
    How hot does it have to be to melt aluminum?:busted:
  12. Reddog Husqvarna
    Michigan
    Aluminum, most grades can melt over 1000Deg F.
    Which is not out of the realm of exhaust temps.
    I had my doubts when I installed it. But figured I wasn't the first to run one.
  13. Reddog Husqvarna
    Michigan
    Update on the fix to quiet this LV3.
    Well after this little fun time of the db-dawg failure, I needed to figure out what to try next.
    So I ordered up some materials.
    Screen for a replacement Spark arrestor. http://www.mcmaster.com/#9238T705
    And some SST sheet to make a flange for the Spark Arrestor.http://www.mcmaster.com/#88885K13
    Turns out it worked well for making a baffle also.
    So here is what I tried today. It is as quiet as the DB-dawg, but must flow better. The bike now has the stumbles and fluttering like with a open LV3.
    I have a Iridium plug to change to first. If that doesn't fix it, time to go to the power up plug.
  14. Nesbocaj Husqvarna
    I found that my bike ran poorly with just the LV can.
    The removal of the lambda with the resistor mod and the iridium plug and the home made LV restictor all together made the bike run great. It seems to run better with the restrictor in place than without it. :thumbsup:
  15. EWS Husqvarna
    Louisville, KY
    Is the LV can without the restrictor a straight-through pipe?
  16. rajobigguy Administrator
    So.Cal.
    Yes, basically a glass pack. It's still a straight through with the restrictor just a bit smaller diameter.
  17. EWS Husqvarna
    Louisville, KY
    Thanks:thumbsup: That was the last piece to my puzzle. I'm going to dyno my stock bike tomorrow night. Then open up the air box, install the power-up/resistor, recore the stock exhaust with a straight-through-baffle and slight restrictor, and re-dyno it.
  18. Reddog Husqvarna
    Michigan
    WOW, What a difference. Changed to the powerup plug and it is nice.
    No bobbling, it will pull you along at an idle now.:thumbsup:
    I still need to put the Iridium plug in, I didn't pull the tank all the way off this time. Just enough to get to the 02 sensor.
    The NAPA plug was under $4. here. I also got a copper washer to seat the plug in.
    Radio shack was out of resistors, so I stopped by a local electronics supply. They cost me two times what RS wanted but they are also a better quality.:cheers:
    Now to see how my mpgs will be affected:excuseme:
  19. xymotic Husqvarna
    Federal Way, WA
    Jeeze, MORE expensive than Radio Shack?? I never heard of such a thing!?
  20. Reddog Husqvarna
    Michigan
    The ones they had where an industrial shielded 2.2K OHM 1/2watt 2% error.
    For $2 for 5pcs. Really broke the bank.
