FE/FC license plate bracket
Discussion in '4st' started by nep2012, Apr 25, 2015.
  1. nep2012 Husqvarna
    2012 te 310
    Just bought a 2015 FE 350 want to put my plate on it. Anybody know where you can get a good sturdy license plate bracket.
  2. octagon pilot Husqvarna
    Desert Southwest
    2015 FE501s 2009 TE610
    YZ450FX Tenere 700
  3. Hoov165x Husqvarna
    Carlton, OR & Sunriver, OR
    The Latest: 2014 FE250
    Husky Power Parts has a cool quick detach one.
  4. Johnrg Husqvarna
    Santa Barbara
    2013 TE 310 R
    I do not like license plate brackets as I don't need to promote any company with it and they are usually made as a way for a dealer to advertise, not as a better way to hold the plate. Find a good backer for it and trim to match the plate and call it good. I used an old number plate. Similar plastic to the bodywork/fender but thicker. Enduro Engineering I think, makes a generic black backer plate.
    reveille likes this.
  5. cahuco Husqvarna
    NY, USA
    2015 FE350
    Hello all,
    Sorry for the newb question... not sure if I'm going with 350 "S" or non-S.
    If I end up with the 'non-S', will its tail light function as a tail & brake light if I simply add a pressure switch?
    Or must I get an aftermarket tail lamp assembly that will?
    Thanks for any wisdom!
  6. nep2012 Husqvarna
    2012 te 310
    Just got a 2015 FE 350 and no there is no brake light the dealer hooked it up so it worked with some wiring. No aftermarket tail lamp assembly, Took him like 10 minutes.
    cahuco likes this.
  7. nep2012 Husqvarna
    2012 te 310
    Thanks. I ordered the one from Rocky Mountain a buddy has a KTM 350 and says his worked fine its basically the same thing.
