FE/FC light kit for fx
Discussion in '4st' started by nep2012, Aug 13, 2016.
  1. nep2012 Husqvarna
    2012 te 310
    does anyone know what is involved putting a headlight and tail light on a 2017 FX 350? any stator tweaks?
  2. tsqurd Husqvarna
    fx350
    Depends. The stator in the FX is the same one that is in the new FCs and KTM SX and XCFs. The stock stator puts out just enough to power the base requirements of the bike plus a small reserve (20 Watts per Baja Designs) . The reserve may be enough to power a low draw light set up - Sicass makes one for the KTM, but you'd have to piece one together for the Husky. Now if you add grip heaters or a fan as well (the trail tech fan draws 30Watts) you are asking for trouble in my mind, especially on a bike with no back up kick starter. Safer bet would be to put in a higher output stator or to have the stock stator rewound.
  3. Weantright Husqvarna
    Burton, Oh
    2019 FX350 w/KYB Inserts
    2017 FE250 w/OC, 2016 XTrainer w/KYB
    I found no upgraded aftermarket stator for these bikes. A rewind is your only option.
  4. robertaccio Husqvarna
    San Diego, Ca
    2021 Husqvarna TE300i
  5. robertaccio Husqvarna
    San Diego, Ca
  6. Huskynoobee CH Sponsor ZipTy Racing
    Castaic, CA
    2011 TE449 2006 WR250
    Would the FE stator work?
  7. tsqurd Husqvarna
    fx350
    That is TBD on the new bikes, but I'd bet one could do it. On the last generation it was possible, but perhaps not cost effective. Using the FE/EXC stator required adding a spacer, plus several other parts. I haven't priced the components out my self, but read that it was significantly more expensive than a rewind or trail tech stator.
  8. Brapman629 Husqvarna
    NW PA
    2015 FE350!
    2009 KTM 250SX-F (Wifes)
    This is what I was thinking.
