TE/TC Linkage hardware??
Discussion in '2st' started by be350ka, Dec 14, 2014.
  1. be350ka Husqvarna
    2015 TE 250
    I'm picking up a 2015 TE250 in a month when it arrives, but I'm currently getting my ducks in a row for its arrival. I have always been a fan of ensuring that the bearings are well lubed prior to the season starting and plan on doing just that over the winter. However, I need some help here from those of you who already have this bike in the garage.
    1. Are the bearings still coming pretty dry from the factory? It seem that it depends on which day they were assembled.
    2. Does the 2014/2015 Husky have that darn cone nut with a flat side to secure the dog bone to the frame?
    3. Can someone post some good picture of this area if in fact they are using the nut from hell as described on KTMtalk.
    4. Those of you who have remove the linkage and swingarm for a touch up what did you find with the hardware and the condition of the bearings? Did the cone nut give you fits? Stories welcomed.
    Thanks again for your help guys!! I'm already happy to be in.....well, close to in the club. I'm very excited and hauling my buddy's TE125 home for him yesterday didn't help with the wait. Oh well, I need the rest as I found that mashing your wrist into a tree only results in plates and 11 screws. On the mend.....
  2. troy deck Husqvarna
    Republic MO
    87 250wr 12 cr125
    kx65 ty80 rm80 kdx250
  3. Norman Foley Husqvarna
    Sorry about the wrist and good luck with the bike. I'm about to take my new TE125 linkage apart, so I'll look. Too excited for your friend, to look at his TE125 when you hauled it for him?:busted:
  4. be350ka Husqvarna
    2015 TE 250
    Yea, he's been following your 125 thread quite closely. Heck, who am I kidding. I followed it too. He is going to love the weight difference moving from his FE390.
    I was up until 2am last night/this morning researching parts for these bikes and it seems that the 125 uses the same nut on all three bolt/link locations on the links. Big plus for you 125 guys. I'm going to have nightmares about that stupid cone nut and the gobs of triple red loctite that they apply so that the bike doesn't fall apart in a crate. Grrrrrrr..... Oh well, Slavens did a video and mentioned that the key is lots of heat. So, I will go that route when I go for the tear down I guess.
    Pics are always welcome and if we share our experiences it will save someone some grief in the future.
    Thanks again!
  5. be350ka Husqvarna
    2015 TE 250
    I'm sharing pictures for you Kev.... Didn't think that you'd mind.
    Saturday afternoon after the score! Looks lonely without its buddy yet to arrive...
  6. BDHANSON Husqvarna
    Southwest Washington
    2014 TC250
    I greased all bearings the day I picked my 14 TC250 up. I had no problems with any of the hardware. I used slow and steady pressure and made sure the nut stayed captured to the flat on the dogbone. It looked like they only used assembly lube for the bearings. I use bel-ray waterproof grease.
    Sweet looking small bore! Congrats
    be350ka likes this.
  7. Kevin A Husqvarna
    '15 TE125
    Former '11 Berg FE390
    Beat me to the punch bro! I was about to throw that one up! You're right....so ronery!! Needs a buddy ASAP.
  8. Lincolnlock Husqvarna
    Mount Vernon, WA
    The linkage on my bike had plenty of grease. I did add some because it was apart for a linkage skid. It came with the cone nut. It comes off very easy with a bunch of heat. The red loctite takes quite a bit of heat to get it to release. Just be sure that the nut stays up against the linkage as you remove the bolt. And lots of heat. Did I mention heat it a lot? I've had two linkage bikes with these. It's no problem.
  9. be350ka Husqvarna
    2015 TE 250
    Thanks for the input. You say red loctite? Maybe KTM changed the loctite because it seems that the 2012 KTMs had green.
    I'm putting the linkage guard on my bike too thus my fascination with that nut.
    What did you use for heat? Heat gun or torch? How long did you heat it?
  10. be350ka Husqvarna
    2015 TE 250
    Also, did you rely on the frame tab to hold the nut? Or did you use the vice grips that everyone seems to be using?
  11. mike243 Husqvarna
    2012 wr 300 FOR SALE
    yz 450 ( built to go fast) yamaha R1
    what linkage guard is everybody using?
  12. be350ka Husqvarna
    2015 TE 250
    I'm going with the Fastway/Stillwell.
  13. BDHANSON Husqvarna
    2014 TC250
    I'm going to go with the blue Slavens linkage guard. He has a YouTube video of replacing a trail tested one. And it's only $90 US
  14. Lincolnlock Husqvarna
    Mount Vernon, WA
    I use the Emperor Racing linkage skid. I beat the crud out of my last one with good results so I bought another one for the 15'. I just used a propane torch to loosen the loctite. Also the frame tab will hold it as long as you maintain pressure to hold the nut against the frame.
    be350ka likes this.
  15. venturini Husqvarna
    USA
    '15 TC 250 '13 CR 150 '11 TE 310
    '12 KTM 250 XC
    Slavens Racing guard on my KTM 250 XC. The nut came off with zero issues....didn't even use heat, just a properly fitting socket and a breaker bar. I had read comments about a few people rounding them off so I was extra careful to make sure the socket was squared up and just gave it a slow and steady tug until it let loose. The linkage was well greased, as were the swing arm and triple tree.
    be350ka likes this.
  16. be350ka Husqvarna
    2015 TE 250
    Good to hear! Thanks for the input.
