250-500cc Linkage oring replacement
Discussion in '2 Stroke' started by firecrotch, Dec 26, 2013.
  1. firecrotch Husqvarna
    north bend, wa
    2009 wr300
    2007 ktm 950SM
    Reassembling my linkage yesterday i didnt notice the side not visible to me I chewed up on those tough orings while tapping the linkage into the swingarm. I tried fixing it but its pretty much trashed. I don't want to buy a whole new linkage kit just to get a replacement oring. Problem is these orings have like a tough metallic inner layer so just going to local hardware store I assume is out.
    Suggestions on where to get a single oring?
  2. MOTORHEAD Husqvarna
    Mount Vernon, Indiana
    2014 YAMAHA YZ250
    All the parts are available individually from a Husky dealer.
    Which ones are you talking about? I only know of two O-rings in the linkage system and they are on the shock mounting point. Those are just standard O-rings you should be able to find at a hardware store.
  3. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    yeh what motorhead said. just did mine the other day as took the shock out. replaced the 2 orings on bottom shock mount as one had been pinched & split. $6 for a pack of assorted orings from autostore. didn't see any other orings, rest are just flat seals?!
  4. firecrotch Husqvarna
    north bend, wa
    2009 wr300
    2007 ktm 950SM
    cool, i didnt know if you could use any oring from auto store because i found out the hard way those things have a hardened center in them like a steel belt tire or something.
  5. flyingbob Administrator
    USA
    01&02WR360_02WR250_02CR250_12WB165
    01 VOR400_07 TM450_22 GG250_07 Tuono
