125-200cc little help
Discussion in '2 Stroke' started by dirtyface, Nov 26, 2013.
  1. dirtyface Husqvarna
    Woodbine GA
    KTM
    On a2012 wr125 how can I tell the power valves apart from the 144s power valves
  2. MotoMarc36 Husqvarna
    wisconsin
    2012 CR144, 04 TC450, 04 TC250, CR50
    Many. Too many.
    144 ones will be slightly shorter.
  3. dirtyface Husqvarna
    Woodbine GA
    KTM
    I can see that on one it has more tapper then the other going into the cylinder
  4. dirtyface Husqvarna
    Woodbine GA
    KTM
    What will happen if I have the wrong on in
  5. rockdancer Husqvarna
    Sunshine Coast, Australia
    2013 WR125, 2019 FE350
    The 144 are shorter - due to bigger bore - measure them :excuseme:
    If 125 ones are used on the 144 you will stuff your motor - they will stick into line of piston
    if you use 144 ones on a 125 they will not work well either
