Little Tricks
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by HuskyDude, Aug 18, 2008.
  1. HuskyDude Moderator
    BC, Canada
    13/TR650
    10/EC300, 76/TY175
    Just thought we could share little tricks to make riding a little
    more fun, safe…less stressful.
    Lots out there but one that comes to mind is adding a little “Locktite” to your Masterlink to help prevent it from coming apart. Or caring a spare in your tool pouch.
  2. Creeper Husqvarna
    Ravensdale, WA.
    As in penny-tech little tricks?
    How about a "universal, one-size-fits-all rear axle alignment tool"?
    I originally wrote this when I had a KTM 640 Adventure. I have a Sherco now... but as it's "universal" it will work just fine for Huskys too.
    OK... so it's not universal. The rod length may vary from bike to bike and it's of no value on a bike with snail cam adjusters like a DRZ for example... or a shaft drive anything. So I lied... so sue me. :rolleyes:
    What you need:
    All you need to make one is a 35 cent piece of steel 1/8” welding rod... about 36" worth, and a zip-tie. For a total investment of what? 40 cents maybe. You can make this tool tricker and fancier... but I doubt you can make it cheaper.
    Get at least 1/8" steel rod for this... smaller diameter or softer materials are too flexy and inaccurate.
    Why you need it:
    Rear axle alignment, with few exceptions, is usually only as accurate as the axle block and swingarm hash marks… which is to say not very accurate at all.
    Rear axle misalignment can cause unstable tracking down a straight road, “odd” handling in corners, accelerated tire wear, brake pad wear and chain and sprocket wear.
    How you make it:
    Cut the rod to length so it is a few inches longer than the approximate distance from your swingarm pivot shaft center to the rear axle center… in the case of the KTM LC4, about 29-30” is fine.
    Grind a point on one end of the rod and bend that end at a 90 degree angle. The length of this bend will vary from brand to brand, model to model, but the idea is to have the major length of rod parallel with the swingarm when measuring.
    In the case of the KTM LC4, a handy length is about ¾”.
    Most dirt bikes will take a straight rod section and a variable length on the short end of the 90 degree bend.
    Now grab a zip tie, put it tight over the long end of the rod and cut the tail off short and to a clean point. Congrats… you have made a tool. :D
    If you need to, you can make more complicated sets of bends to clear things that are permanently in the way. The drawing is an approximation of a tool for a '79 to present Harley-Davidson with a rubber mount driveline.
    How it works:
    On a KTM LC4, there are rounded plastic buttons in both ends of the swingarm pivot shaft and one on the fixed end of the rear axle… and then an aluminum axle nut.
    If you don't have plastic buttons, you've got a pivot shaft end, or a cap nut or both.
    Still works... just make sure you're on center.
    It doesn’t matter which side you start on. You place the pointy end in the center of the plastic button (or what ever you have) on the swingarm pivot shaft...
    ... and slide the zip-tie so the pointy end of it aligns with the center of the axle… that is the "reference length" for one side.
    Now you transfer the tool to the other side and see where the center of the axle is in relationship to the reference length.
    Adjust that side of the axle (or both sides, more or less) until both sides measure the same distance by the tool, then using the current alignment as a baseline, readjust your axle for proper chain tension for your particular bike.
    That's it... you done.
    This is the "whole tool"... nothin' but the tool. :p
    So, with a 40 cent tool, you can potentially get your axle aligned to an accuracy of well under one millimeter. The accuracy of the tool is based on the users consistency.
    So there ya go,
    C
  3. Poopy Husqvarna
    Kamloops, BC
    WB165
    very cool!
  4. Norman Foley Husqvarna
    I use a variation of creeper's tool as a "one man" sag measurement tool. I used a length of flux cored aluminum welding rod, as that's what was handy.
    Norman
  5. Creeper Husqvarna
    Ravensdale, WA.
    Hey Norman... [IMG]
    Yep... me too. Hook the 90 end into the slot corner in the swingarm and just slide the ziptie to your reference point. That's one way to do it... I'm sure there are others depending on the bike.
    Needing help to check sag is just plain... wrong. :D
  6. Norman Foley Husqvarna
    Creeper,
    I need to hook up with you for an '03 TE610E seat job this Winter.
    Norman
  7. raisrx251 Husqvarna
    Virginia
    Here is my (or CH's) trick for the kick stand on my WR 250. Not sure if you TE owners can use this or not.
    [IMG][/IMG]
    [IMG][/IMG]
  8. Motosportz CH Sponsor
    That's a good one (thumbs up)
  9. neversurfaced Husqvarna
    Well, to be honest I didn’t think of this one myself, I just happened to wonder across it the other day at Costco. I figured with all the sidestand issues us 08 TE owners have been having, that this might come in handy:
    Apparently, all that is required is a packing tape dispenser, and viola:
  10. flight120 Husqvarna
    Denver, CO
    I really kinda want to see that bike on it's sidestand without the tape dispenser!
  11. HuskyDude Moderator
    BC, Canada
    13/TR650
    10/EC300, 76/TY175
  12. Coffee CH Owner
    LOL...
    Everyone seems quite impressed! Never would have thought of it had I remembered to fill up the kids XR100 so many years ago. It helped to have snacks in the back pack.
  13. SightedN2 Husqvarna
    USA
    another little idea...if you can find one now....I use a 35mm film (plastic tub thing) to store a few small bolts, washer nuts of stuff that might fall off, its came in handy more than once on long rides, carry it in my front fender, tube bag. or fanny pack
  14. SwitchThrottle Husqvarna
    Canton, CT
    I always carry a 3' piece of clear hose for fuel swaps. They call my bike the XR-valdez as it as the 3.8 gal clarke on it.
  15. Riksha Husqvarna
    So Cal
    Google sailboat sail tape.
    When your graphixs begin to peel/fall off the bionic double sided tape works real well. Sail boat tape is pretty good stuff, I have seen 'Venture' and 'Tytan'. Venture being the stronger of the two. Much like the 3M stuff you see at office depot but way way stronger.
  16. somdale Husqvarna
    Southern Maryland
    Put a light coating of lithium (white ) grease on the inside surfaces of your air box and side cover areas. This acts as a pre-filter for your air filter trapping all kinds if stuff before it hits your air filter. You'll be surprised how much crap it traps.
  17. rajobigguy Administrator
    So.Cal.
    Tips and tricks
    This one might need to be made into a sticky at some point. The idea here is just what the title implies, a place for us to share our collective knowledge of all the little things to bail us out of a bind or just make life easier.
    I'll start off with a few and add more as time goes by.
    THREADED THINGS
    Ever strip a threaded hole? Come on now be honest, there are lots of threaded aluminum pieces on our bikes and just threading and unthreading bolts enough times will wear out the threads in the aluminum.
    The best way I have found to repair stripped or worn threads is with a solid threaded insert. There are several types available but in my opinion the very best you can buy are Time Serts.
    http://www.timesert.com/
    How about breaking a tap?
    Broken tap extractors are available from McMaster Carr.
    http://www.mcmaster.com/
    Hand and Spiral-Point Tap Extractors
    Remove broken taps and save threads without drilling or using special tools. Extractors have hardened steel "fingers" that fit in the flutes of a broken tap so you can remove the tap without damaging the workpiece threads. Their square shank is compatible with standard tap wrenches. Use on right- and left-hand NC, NF, and metric threads. Made of steel.
    Extra fingers are sold in packages of 12 unless noted.
    Pipe tap extractors and extra fingers for sizes 1/8" to 1/2".
    If it is an emergency you might be able to make you're own tap extractor. Simply take the shank of the tap that you broke and place some small brad nails in the recessed area of the flutes then using some 5min. epoxy like JB quick weld you can secure the brads in place. Now use a small hose clamp over the epoxy to add a bit strength and you will have a homemade tap extractor its not a s good as a commercially available one but it might get you out a bind in a hurry.
    What about those pesky studs and pipe plugs that wont come out?
    There are many things that can cause this; maybe someone used red loctite when they were assembled, rust and corrosion or two dissimilar metals that have created an electric potential and the two pieces have began to plate out on each other.
    One way of breaking them free that always seems to work for me is to use a torch to heat the stud or pipe plug until it glows red then let it cool down until it is just very hot and spray some penetrating oil around the threads. After letting it cool completely it will usually come out with little more than finger pressure.
    Speaking of penetrating oil. There is a difference between a light lubricant such as WD-40 and real penetrating oil like Liquid wrench. They both have a purpose for which they are best suited and Liquid Wrench is better suited to aiding the removal of stuck bolts but you can make you're own penetrant that outperform almost anything on the market by making a 50/50 mix of diesel fuel and ATF.
    More to come later please feel free to add any of you're own magic acts to this thread.:cheers:
  18. tony_dt Husqvarna
    TX
    Good Stuff. I like PB Blaster though for penetrating oil. Got me out of a few binds.
  19. Coffee CH Owner
    Great info!
    Didn't we already have one of these threads going though?
    At the risk of stating the obvious I am way way way behind on filing things so people can find things. That will be done though so the information is not lost.
  20. Ruffus Husqvarna
    I've been wondering if there's gonna be an important info sticky. I seem to recall something like that in another place :D:cheers:
