Longer battery post screws
Discussion in '610/630' started by tool46n2, Jan 19, 2012.
  1. tool46n2 Husqvarna
    Chicago
    The number of connections to my battery is growing and the current screws can no longer accommodate all of them...anyone know where I can get longer screws?
    Thanks
  2. mnb Husqvarna
    San Jose, California
    2011 TE310 . . . . 2003 TE610e
    Get a fuse block. They aren't that cheap ($50-80 or so), but you run one line from the battery to the fuse block and then you have individual screw terminals for every device you wire. Some fuse blocks have a relay that allows for ignition on powering the line. Handy for stuff you want to make sure doesn't drain your battery. A fuse block really cleans up things and makes it easier to work on and diagnose problems. ...Says the guy that doesn't have a fuse block and has a rat's nest on several bikes.
    A hardware store should have a bolt that will work. The trick will be getting one that is longer but not too long so that you can't get a tight fit.
  3. Runner Husqvarna
    Los Angeles, CA
    2006 TE510
    There's nothing special about the battery screws, just go to a hardware store that carries metric hardware and find a screw of the same thread size, just a few mm longer.
    Another far less expensive alternative to a fuse block is a terminal block from Radio Shack. You bus the +12 Volt across server terminals easily.
    mnb likes this.
  4. mnb Husqvarna
    Is there a Monthly Pass available? Or at least a Day Pass? Riding the bus gets expensive otherwise... :D
  5. Runner Husqvarna
    Los Angeles, CA
    2006 TE510
    Wow, that was amazingly bad typing. I meant to type, "You can bus the +12 Volt side, along with the ground side, if necessary, across several terminals easily." This will allow unimpeded attachment of many accessories. These terminal blocks are available in configurations from two pairs binding posts to at least 12 pair.
    Another one rides the bus!:D
  6. JoiseyJanet Husqvarna
    New Jersey, USA
  7. mnb Husqvarna
    Hey! He's gonna sit next to you, another one rides the bus.
    Fixed link which had been corrupted by Microsoft.
  8. 1lunger Husqvarna
    Bloomfield CT
    The bolts are the same width as the one for are box 8 or 10 mm, I think it's 8 mm w/ 1.25 pitch.
