Longer Shift Lever?
Discussion in '610/630' started by Wrryder, Oct 20, 2011.
  1. Wrryder Husqvarna
    I need a longer shift lever to accomodate my longer than normal foot. Does anyone know if one is available or will I need to weld two of them together to make a Frankenshifter?
    I wonder if the selector shaft dimensions are common to any other bikes?
  2. Kevin2735 Husqvarna
    Summerland, CA
    I have the same request. Being not so mechanically adept at things, I would prefer a solution that does not involve milling, drilling, sawing, or otherwise banging on a large stone.
  3. lankydoug Husqvarna
    MO
    WR
    TM 300en
    A +20mm Hammerhead shifter tip can be put on a stock lever or a Driven lever with very little modification. I wrote a post about it in the 2 stroke section.
    Goldenh likes this.
  4. Russ Husqvarna
    Sydney
    TE250i & 701 Enduro, 501 & 630 sold
    The part number and description on the sales invoice I received for the Hammerhead tip on my bike is:
    HD100112 Hammerhead Gear Tip 20+
    That part no. can be found at:
    http://mainmoto.com.au/hhcat/cat/
    HAMMERHEAD DESIGNS BILLET & RUBBER BOOT SHIFT TIPS
    Original Knurled Tips
    +20mm Wide Tip
    100112
    I posted some pictures of it on my first thread "New Member and TE630 Owner" in July if you are interested in having a look.
  5. Kevin2735 Husqvarna
    Summerland, CA
    http://www.powersportsuperstore.com/Hammerhead-Designs-Billet-Shift-Lever-20mm-Tip-p/4179111.htm
    This looks like one that is state side, for $18 I'll give it a go. Do you think the Driven shifter lever for the TE510 will work on TE630? I read another post where someone used a particular KTM shifter, I think for a 530, but had to bend or tweak it to get it to fit?
