looking for 2011 TE 310 with TXC ecu and 12 hole injector settings
Discussion in '4 Stroke' started by Green Mtn Rider, Nov 28, 2016.
  1. Green Mtn Rider Husqvarna
    Vermont
    2011 TE 310
    I just got a 2011 TE 310 with the TXC ecu and 12 hole injector. It also came with a Akrapovic exhaust. I have the I Beat tool. I want to check the tps and co1 co2 co3 settings. What are the settings that are a good to run 0-3000 elevation?
  2. glangston Husqvarna
    2012 Husqvarna TE 310
    2012 BETA 350 RS
  3. Green Mtn Rider Husqvarna
    Vermont
    2011 TE 310
    Read through this thread but did not see any info for the TXC ecu and 12pt just stock TE and 4pt
  4. glangston Husqvarna
    2012 BETA 350 RS
  5. Green Mtn Rider Husqvarna
    Vermont
    2011 TE 310
    I looked at it again and the #s seemed to be with the TE ecu and 4pt. It would be great if next week you could give me your co#s and tps setting.
    Thanks Wayne
  6. R_Little Husqvarna
    NJ
    1st set the TPS to 102.3 at WOT.
    Should be about 970mv if memory serves.
    If you run the SA screen 100 100 100 might work fine. A little higher if no SA.
    The TPS is critical. I've seen a few bikes way off.
  7. glangston Husqvarna
    2012 BETA 350 RS
    Did you post #'s on a TE 310 with TXC ECU and 12 pt. Injector or a stocker with 4 pt.
    OP, I will try and get the #'s but realized I'm not bringing that bike home this week so will be awhile. I'd agree 100 across would be a start then ride test. George (Uptite) did mine and I'm sure that's how he settled on the #'s, taking it around the block a few times.
  8. Green Mtn Rider Husqvarna
    Vermont
    2011 TE 310
    No problem winter time here when you get a chance to check will be great
