Looking For Suggestions On Refreshing Engine
Discussion in '4 Stroke' started by Carminuch, Nov 21, 2018.
  1. Carminuch Husqvarna
    txc 310
    kx250f
    Hey I have a 2012 txc 310 with 250hrs on the engine. It still runs strong starts one or two kicks but I have noticed it blows some smoke till it warms up but it then seems to stop. Being that its winter I was going to Refresh the motor with new seals pistion and rings and timing chain. Im looking for suggestions on what else should be replaced and also were to get the parts. I do have the manual and have read over it.
    thanks
  2. Trenchcoat85 Husqvarna
    Northern NorCal
    '14 TE 310R
    sounds like you got it covered, if the valves, seats, guides are good. And, if so- bet'cha rings and stem seals only freshen it up. might get another 250 hours out of it.
    timing chain: should be good but check. And check the lobes, check the top & bottom end bearings, and check cylinder of course- these will turn a $200 job into $1000+
    ring gear for the starter? sounds like you kickstart mostly tho. How many clutches?
    good luck- keep us up to date.
