Looking for the correct way to fill cartridge body (45MM Marzocchi SHIVERS)
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by Scott Stanford, Sep 21, 2011.
  1. Scott Stanford Husqvarna
    I have an 06 CR125 with the 45mm dual chamber forks. I'm changing the fork seals/dust seals. Does anyone know the correct method for refilling/bleeding air out of the valving chamber (Cartridge body) ?
  2. robertk61 Husqvarna
    Melbourne, Australia
    09 WR250
  3. R_Little Husqvarna
    NJ
    Did not think the 45s were dual chamber?
    I have an FBF set on my 135 with the TIN coated fork legs and they are open style?
  4. Fat Tire Flyer Husqvarna
    Canada
    My 2006 Husqvarna WR250 has Marzocchi 45mm Shiver Forks.. Think it's the same for a 2006 Husqvarna CR125 (but not sure)..
    This is the service manual I used when I overhauled them last year: Marzocch 45mm Shiver Fork Service Manual..
    Hope that helps.. Good luck and cheers.. :cheers:
  5. Parh 474 Husqvarna
    Newbury Park, CA
    '73 Cr125, '06 Cr125/144
    Ossa, Bultaco, Puch, Maico, AJS, Yam
    I have a '06 Cr125 and it has dual chamber Marzocchi 45s with the Kazima coating.
