250-500cc looks like my 07 WR250 has a foamy milk option :P
Discussion in '2 Stroke' started by mr_manny, Nov 7, 2021.
  1. mr_manny Husqvarna
    Jalisco, Mexico
    wr250
    Still going through my new-to-me wr250.
    It has issues, which the most recent is a milky substance coming from the case breather.
    I don't have a 23mm socket to pull the drain, so that will have to wait until tomorrow.
    I will be pulling the pump cover tomorrow, but have already started researching water pump seals.
    Does anyone know where I could find one?
    Thanks
  2. mr_manny Husqvarna
    Jalisco, Mexico
    wr250
    Found a seal kit on ebay.
    Other then the reverse threads on the impeller, any other pointers I should know about?
  3. mr_manny Husqvarna
    Jalisco, Mexico
    wr250
    ​Pulled the pump.
    I was able to remove the drain-plug with a crescent wrench, couldn't find a 23mm socket locally.
    Milky, Milky, Milky.
    I noticed the drain-plug was kinda ruff, since it's made out of aluminum.
    I carefully filed the edges, reducing the outer size to fit snugly with a 7/8th socket
    Now back to the water pump seal.
    I was able to pull water pump cover, impeller, spacer and seal.
    Didn't find the o-ring behind the spacer....or maybe item #3 is the seal?
    Screenshot 2021-11-08 at 16-28-47 Your source for OEM Husqvarna Motorcycle parts .png
  4. mr_manny Husqvarna
    Jalisco, Mexico
    wr250
    Here's a close-up of the seal.
  5. Hurky Husqvarna
    Spain
    ex: WR300 2010
    Honda CR500AFX + Beta RR300
    mr_manny and Dirtdame like this.
  6. mr_manny Husqvarna
    Jalisco, Mexico
    wr250
    Outstanding thread.
    Thanks Hurky :thumbsup:
    Yup, going to replace the impeller.
    I may have a local machinist make one...wish me luck.
  7. mr_manny Husqvarna
    Jalisco, Mexico
    wr250
    Picked up water pump impeller from machinist.
    I think it came out better then OEM :)
    flyingbob and 2premo like this.
