Loose part in rear Sachs shock?
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by Soderberg, Apr 14, 2012.
  1. Soderberg Husqvarna
    SkellefteƄ
    2014 TE 310r
    Gasgas ec250 -18, Yamaha WR250F
    I have an almost new 2011 TE 310. Have only driven it about 5-6 hours with the original spring. Ordered a harder rear spring as I weigh 85 kg. When I took the shock out of the bike I heard a sound inside it. It sounds like something is loose inside the shock. It sounds like a metal part and every time I turn or shake it. My question is if this is normal? Do the Sachs shock have some kind of loose part inside that has a purpose (valve or something else)?
    Ola
  2. Sparked Husqvarna
    Beaverton, OR
    No. I'm near certain that mine didn't make any noise, and I saw nothing inside that should be loose.
    Can you tell where the noise is coming from? The body, the clevis end, or the reservoir, etc?
    Wild guess here, but it could be the rebound adjuster rod. Turn the rebound adjuster all the way in (clockwise) and see if it still makes that noise. That's the only thing I can think to check that doesn't require disassembling the shock.
  3. Sparked Husqvarna
    Beaverton, OR
    I actually rebuilt my shock today, and checked. No rattling at all. I couldn't make the rebound adjuster rattle, so that was a red herring.
  4. Soderberg Husqvarna
    SkellefteƄ
    2014 TE 310r
    I have talked with the company that sold the bike. He had to call Husqvarna and according to them some of the Sachs shocks have a sort of valve inside that makes a noise. For me that sounds crazy but I have to trust them. Except for the noise it works as it should. The noise comes from the body.
    I have put it back on the bike and Ill run like this and see what happens. At least I have the answer from the seller on my email, so if it explodes :applause: I hope theyll give me a new one. If not I guess i shouldnt have bought their excuse :doh:. What bike and year do you have?
  5. Sparked Husqvarna
    Beaverton, OR
    Ok, if they say so, then that's pretty definitive.
    Mine's an '11 te250
  6. huskybear Husqvarna
    B.C. Canada
    I have a noise from my rear shock as well, it is like a click when you compress the rear suspension and a click when it extends again. all the linkage and shock bearings are like new and the sound is coming from the shock body. It seems to work fine, I guess mine is "normal" as well:thinking:!
  7. Pedec Husqvarna
    Sask.Canada
    My 2010 tc250 sacks shock does same thing can not hear it while riding. I think this is a normal thing with this shock and can be fixed buy some suspension tuners. Does not affect the way shock works for me so far. I took apart my linkage also and everything was fine.
  8. jo360 Husqvarna
    perth australia
    1983 exc framed wr430 engine
    ktm 520exc
    cannot see anything that should be making a noise within the unit other than maybe the check valve openining and shutting but should be non audible unless your oil is super thin.got an email from gas gas rider today about Les from ltr who is now recovering from a massive heart attack, not dealt with him myself but apparently a top bloke all the best Les.
  9. dartyppyt Husqvarna
    Illinois
    17 TE 150, 82CR 500
    There is an issue with those shocks and Les @ LTR knows what to do. I would call Drew @ WER Racing. They can sometimes tell you what the dealer fix is when you are far away.
  10. MOTORHEAD Husqvarna
    Mount Vernon, Indiana
    2014 YAMAHA YZ250
    Some of them have a check ball in the rebound circuit that might cause it.
  11. huskybear Husqvarna
    B.C. Canada
    I was at my husky dealer today and they have a 2010 cr125 there. I checked if the rear shock had the same noise as mine and it did, I am thinking that it is normal for these shocks and that we should not worry about it too much and just enjoy the ride(at least until something breaks:eek:)!
  12. Soderberg Husqvarna
    SkellefteƄ
    2014 TE 310r
    Back after some months. Today I have had 60 hours on the bike. Felt it wouldnt hurt to change suspension oil and look over the suspension overall. Here is what had happened to my shock. On top of the nut holding the shimstacks its a smaller nut. That 12 mm nut is a part of the rebound circuit and keeps a spring and ball in place (works as a valve). The 12 mm nut together with the ball was chaking around on their own, completely loose from the place they belonged to. The nut was damaged quiet good, the ball looked fine and the spring must have been gone up in atoms as it cant be found. I have had some problems with getting the rebound to work properly. Now I know why. Called Husqvarna here in Sweden and he had never heard of anything like this ever. Sachs dont sell those parts by them own. Had to order a complete piston rod. Luckely I dont have to pay for it. Sadely I have to cancel the plans for a competition on Saturday. My guess is that they forgot the Loctite when assembling it.
    Ola
  13. huskybear Husqvarna
    B.C. Canada
    :thinking:
