Loss of power and rough idle
Discussion in '610/630' started by Chillybean, Apr 8, 2013.
  1. Chillybean Husqvarna
    Canberra
    TE 310, SM630, 72 WR 250. 89 WR 250
    While riding home from work my SMS 630 started to run poorly, Idle speed has dropped from 1800 rpm to around 1400 rpm and a huge loss of power, struggles to get the front wheel off the ground in first gear:cry:. It starts fine and is not making any unusual noises. It's a stock bike except for the basic PU kit and only has done 1000km.
    Where do I start?
  2. RDTCU Husqvarna
    '11 630SMS
    A few possibilities, in order of likelihood:
    -bad gas
    -dirty air filter
    -bad spark plug/wire/coil
    -bad fuel pump
    -bad throttle body
    If the temp sensor goes bad, you usually have trouble starting it.
    Does the fan run more than normal?
  3. KXcam22 Husqvarna
    Kamloops, BC, Canada
    2011 SM630, 2017 300XC
    08FZR6;07CRF450;98CBR900RR;02KTM200
    It does sound like plugged injectors caused by bad gas. Cam.
  4. Chillybean Husqvarna
    Canberra
    Called my local dealer today and explained the symptoms, he suspects low fuel pressure, goes in for him to look at tomorrow. Will let you know the outcome an if it's covered by warranty.
  5. Chillybean Husqvarna
    Canberra
    Found out today it was a bad fuel pump. The pump was making just enough pressure for it to start then run like crap. Still waiting to see if it will be covered by warranty.
  6. DYNOBOB Husqvarna
    I think yours is the first 630 pump failure I've heard of. Do you have ethanol in your fuel in Aus?
    It was a little work, but I added a fuel pressure gauge under the speedo and a led hooked to the pump wires on top of the speedo.
  7. Chillybean Husqvarna
    Canberra
    We do have ethanol but I refuse to use it. I only run premium 98 octane fuel. I work for the petroleum industry servicing pumps and other stuff, definitely not a fuel contamination issue as I always pay extra attention to which sites do have issues and never fill up there.
  8. DYNOBOB Husqvarna
    You're lucky, all of our fuel has 10% eth and talk of allowing 15%.
  9. Chillybean Husqvarna
    Canberra
    Fuel pump replaced under warranty:applause:
    djc likes this.
