Not a good idea! Just order a new rubber block for the inside. I think they cost about $20, maybe less.I have a 06 610 sm. and the rubber insert is almost down to the metal! Would it be ok to just remove the guard below the swingarm? Any issues or problems would occur if removed?
Problem is OEM is welded in place! (often not that well aligned as well). How are people fitting the BRP?BRP makes a nice chain guide.
The BRP bolts right up to the welded tab.Yeah sorry my bad - momentary brain fart! - it is the mounting tab that is welded on the swingarm and sometimes not that well aligned. Lunger that does not look like the OEM 610 one??
It's the OEM one. I had it powder coated red.Yeah sorry my bad - momentary brain fart! - it is the mounting tab that is welded on the swingarm and sometimes not that well aligned. Lunger that does not look like the OEM 610 one??
I believe all the guides and rollers are there to compensate for the longer travel rear end (vs a street bike) and looser chain requirement to allow said travel, and the fact that at extreme compression/extension, the chain rubs on various parts of the bike. On a street bike, the suspension is really never in a position that the chain could derail from the sprocket. The chain is simply never that loose. On a dirtbike, different story.I was helping a ADV traveler this week get his BMW 650 Dakar ready for his Mexico to S. America trip and noticed it didn't even have a chain guide. And my street bike doesn't have one. As far as I know, they are to keep the chain on for offroading should you hit something that would knock the chain off. It won't come off by itself just running around the sprockets. For an SM I wouldn't worry about removing it all together.
8.7" on the Dakar
12.6" on the TE630
4.9" on the 2006 Kawasaki ZX-10R
Unsure about the SM630.
Yeah, it's probably there for a reason.5.7" on the Kawasaki Versys (I have one)
11.4 on SM630
I'd probly keep the lower chain guide.![]()
