250-500cc Lower Rocker Bearing alternative.
Discussion in '2 Stroke' started by MOTORHEAD, Nov 26, 2009.
  1. MOTORHEAD Husqvarna
    Mount Vernon, Indiana
    2014 YAMAHA YZ250
    You WR guys know that the lower shock rocker bearings are a pain and require constant servicing. I ran across an alternative bearing on the SYNERGY SEAL site. Here's a link.
    I've got one on order and I'll post more on it when I get it.
    Just thought you might like to know.
  2. demi Husqvarna
    Cheyenne, WYO
    12 WR 300
    '14 SH 500, 81 Gilera 125 C1, 17 KTM
    I am interested in that bushing...almost bought it the other day. Looking forward to hearing your review first.
  3. razornpc Husqvarna
    iowa
    yeah , keep us updated on this! once i get my linkage ripped apart i might end up getting one of these too. always up for improving stuff!
    has anyone here ever drilled a hole tapped it and put another greese zirk in there?
  4. Slowpoke Husqvarna
    Southern Ontario
    http://www.thumpertalk.com/forum/showthread.php?t=661208
    Read the whole thread, as there's pics of installing zerks on the swingarm pivot also.
  5. MOTORHEAD Husqvarna
    2014 YAMAHA YZ250
    I just drilled and tapped mine and the SYNERGY bushing showed up yesterday. It's just simply a little plastic tube that replaces the needle bearing. I'm going to drill a small hole in it, for grease to enter, and press it in.
    Looks like it should be at least as good as the bearing, since I'm constantly finding it rusted up.
    It should also work better for drilling a grease port in. Drilling the needle bearing case without damaging bearings and cage is pretty tough.
  6. MOTORHEAD Husqvarna
    2014 YAMAHA YZ250
    Got mine all mount up and it seems nice. The polymer they used it very hard. I drilled the grease port in it and it wasn't like drilling your average plastic. More like drilling a bowling ball.
    I added a very slight relief to the middle of the bushings to allow grease to flow in and pool.
    Now it's just a test of time, to see how it holds up.
  7. Motosportz CH Sponsor
    I think the all balls kit replaces it with a roller bearing.
  8. MOTORHEAD Husqvarna
    2014 YAMAHA YZ250
    Yeah, I heard that, after the fact.
    But, I like the fact that the poly bearing allows me to make my grease fitting work. I wasn't able to put a port for grease to enter the bearing race without screwing up the bearing.
    I'd probable run into the same thing with the All Balls bearing.
    BTW- I do use All Balls for all my other bearings and the swingarm kit is a way better set up than the stock parts, IMO.
  9. Motosportz CH Sponsor
    Yeah, that bushing is cool and $12. :thumbsup:
  10. Synergy-Seal Husqvarna
    Valley Springs
    Motorhead. How is our P-Bushing working for you?
    Rob
  11. MOTORHEAD Husqvarna
    2014 YAMAHA YZ250
    Working great, actually. I haven't took it apart for a few rides, because I was keeping an eye on it at first and it was doing great. So, I've eased up on the maintenance schedule.
    Good stuff.:thumbsup:
  12. 2stroked Husqvarna
    B.C. Canada
    Do you use the bushing that the needle bearing rides on or does it ride on the bolt ?
  13. MOTORHEAD Husqvarna
    2014 YAMAHA YZ250
    The bushing.
