Kevin_TE250
First off I've looked at this thread and don't quite know the outcome:
http://www.cafehusky.com/threads/getting-lower-steering-stem-bearing-on.16777/#post-147159
taking it off was not a problem as if fell apart.. but there is NO way the Lower bearing or the associated gasket will slide down the stearing stem shaft. I don't see how cooling it would help.. Is the lower bearing supposed to be larger .. HELP!
Kevin..
Kevin..
