Sceep
My clutch takes to high a RPM to engage, and freewheels almost dangerously after rear wheel lockup. It needs to engage at a lower RPM.
I talked to Gary at EFM and he said to shim the clutch pack up to .050-.060 clearance.
I did that. I still want it to engage lower. I shimmed it up to .030" clearance. no change.
So knowing what I do of rekluse z-start clutches (the EFM is similar in construction) and their tuning (which is very little mind you), I know that a lighter spring will lower the engagement RPM.
Heres where i get lost.
The Rekluse uses a spring similar to this for engagement pressure.
the EFM uses multiple stacks of single wave washers like these
so how do i make the single wave washers softer? Remove 1 of them from each stack? flip one in each stack so they are stacked like this (( instead of this () ? order different thickness or material washers and swap them out?
Any help appreciated.
Thanks.
Thanks.
