Maiden voyage w/ my 630
Discussion in '610/630' started by Timberline, May 3, 2015.
  1. Timberline Husqvarna
  2. Magus Husqvarna
    Houston TX
    2011 SMS630
    Aprilia SXV550 Aprilia RS125
    Good luck with getting that sorted. I had an '06 TE610 which was a great bike for me and now have just picked up a '11 SMS630 which has the same rewarding feel. Fueling has been an immediate issue though - I think the JD Power Surge is necessary start.
  3. kirbybikes Husqvarna
    Welcome guys,
    Look into the Dyno Bob thread on fuel injection tuning with either the Ibeat or Power Commander, lots of good info here! I went with the Power Commander and could not be happier, previously had a JD tuner ( I had trouble getting good settings). Lots of happy Ibeat tuners using the data found in the thread. Good luck with everything else, lots of helpful and knowledgeable people on here.
    Kirk
  4. Magus Husqvarna
    Houston TX
    2011 SMS630
    Awww... Don't make me go and buy another PC now... :)
  5. EricV Husqvarna
    Welcome Timberline. Unless you have a good relationship w/ a reputable.good dealer I'd suggest you download and run the Husky diagnostic tool called iBeat. Perhaps that will show you some fault codes that may help you get at what's causing your issues- at least it's a start. You'll also be able to adjust some settings and observe (in more detail, through the iBeat dashboard) what your bike is doing.
    Please let us know what you learn. I'm still having a time starting my 630 (since the engine was put back together after a cracked case) but haven't a clue as to what's causing it. Mine's a cold start issue- hard to start cold (but fine when hot), valves are set right, clean air filter, etc. Runs like a champ also...so not sure what my issue is or where to start. It starts fine hot, but it has to be hot (if it's cooled for even an hour then I have to use the enrichener lever again.)
    Congrats on a great bike...sounds like you're loving it.
  6. Stujam Husqvarna
    Brisbane Austrlia
    09te610, 11te630
    A mate has a 630 with red drc racing hoses . Dont know where he got them as he bought the bike second hand
  7. JonDirt Husqvarna
    London and NYC
    TE610 2008
    My 610 was misbehaving with starting and opening the throttle, turned out to be a missing bolt on the exhaust header. Probably not the same issue here, but it might be worth checking. Usually they are pretty reliable starters. Never been much above 3000' though.
  8. XLEnduroMan Heroes Ride Huskys. The others follow.
    Durham, CA.
    '18 Husqvarna 701 Enduro.
    '20 Ducati Hypermotard 950.
    That is not an adjustment screw. That is a hose nipple for the smog setup. Yours has been removed and plugged with the rubber cap. It is best to remove the nipple entirely and install a stainless cap screw with red Loctite. The rubber can weather and go bad and leave the port exposed. There is info on it here on CH somewhere.
    Timberline likes this.
