major engine braking
Discussion in '610/630' started by huskyfan420123, Sep 4, 2013.
  1. huskyfan420123 Husqvarna
    sms630
    rm125/2012 tomos 150 fun times
    well I have done pu power c airbox 42t sprocket ecu and I just cant seem to get the bike to run good
    hard throttle runs great easy shifts 1st-3rd are notchy and when at low revs like slow traffic my bike goes then when let off throttle it like jerks and shutters when I ease back on the gas its jerky then goes, am I to lean not lean enough
    anyone got their 630 running smooth if so what fuel map did you use
    thanks
  2. RDTCU Husqvarna
    '11 630SMS
    It's going to "chug" down real low in the RPM no matter what you do to it, and engine braking is a fact of life on a big thumper.
    When you say "ECU" what ECU? Any exhaust mods?
  3. huskyfan420123 Husqvarna
    sms630
    no exhaust is next on the list its got te ecu
    I know its a 630 single but its like really bad im talking like letting off the gas at like 3500 rpm
  4. RDTCU Husqvarna
    '11 630SMS
    Get the new exhaust on there that should help a bit. It will reduce backpressure and make it respond to extra fuel a lot better.
    Do you have the stock or 14t front sprocket? The higher your sprocket ratio, the more engine braking you will experience.
    It takes a delicate touch rolling around in traffic slowly, my bike runs great, but at walking speeds it will get jerky unless you're slipping the clutch. I'm thinking about trying out the gen2 Kush sprocket when the stock one wears out.
  5. huskyfan420123 Husqvarna
    sms630
    yea stock14t i never really considered that
    i bought a jt sprocket its great but im kinda broke now so when it wears i got the stocker
  6. RDTCU Husqvarna
    '11 630SMS
    Stock is 15t, but a lot of people replace it with the 14t.
    The 14t would make the engine braking more noticeable.
  7. Theo Husqvarna
    Lombardy, Italy
    SM 610 I.E.
    2001 YZ250
    Many people say, like RDTCU's done, that racing exhausts lessen the engine braking.
    Anyway, if it will still be too much with the new exhaust, you can try to handle it.
    Before the 610, I had a 2 stroke moped, so when I switched to the Husky the engine braking annoied me very much.
    In traffic, when you are in first gear, I think that the only way to reduce the on-off effect is not to release the throttle when you slow down, but close it gradually.
    While, when you're entering a corner, if you don't want to slide, you should do like Lawson in this video at 0:16:
    (He had to reduce the engine braking on a 2 stroke: strange). He opened the throttle to increase the revs, getting rid of the engine brake.
    huskyfan420123 likes this.
  8. huskyfan420123 Husqvarna
    sms630
    I was thinking its my tuning because it wasn't to bad until I opend the air box and the sprocket mod i don't have an auto tune yet so my dealer tunes my bike and it was AWFUL when i got it back at first brought it back and they leaned it out a little and it was better but still very annoying i was asking if anyone has fixed thru tunning that instant on off felling in the throttle
    oh and that vid is so sick
  9. RDTCU Husqvarna
    '11 630SMS
    See how the exhaust helps, it should, but you might just have to lay off the caffeine and be smoother with your on/off throttle :D
  10. huskyfan420123 Husqvarna
    sms630
    hahahaha yea you could be on to something there this thing is a straight ripper
  11. Theo Husqvarna
    Lombardy, Italy
    SM 610 I.E.
    2001 YZ250
    Being smoother with the throttle is the cheapest modification to fix the problem! :D If it doesn't work, at least you won't have wasted money!
    IMHO, it could simply be a matter of gaining a good grasp of the new behaviour of the engine.
    PS: it worked pretty well for my 610: I've learned how to stay more comfortable in traffic.
    Moreover, the "Lawson's trick" (which is not a teen drama ahahah) works very well to let me enter corners without skidding and, obviously IMHO, to stress less the transmission.
  12. RDTCU Husqvarna
    '11 630SMS
    Wuzzat?
  13. Theo Husqvarna
    Lombardy, Italy
    SM 610 I.E.
    2001 YZ250
    Ahah, it's the name I've given to the Eddie Lawson's techinique shown in the video I posted yesterday!
