Making new 430/500 auto 1st clutch springs
Discussion in 'Vintage/Left Kickers' started by Michel Dufayard, Jun 24, 2014.
  1. Michel Dufayard Husqvarna
    France
    I'm in the process of making new 1st clutch springs for 500 ae.
    They can fit on 430 ae. The price will be under 10 € each with shipping.
    I'd like to know if Café Husky riders are interested to get some.
    PM me if interested.
    I have measures like that:
    -diam wire:3.5mm
    -diam coil:18 mm
    -lenght between hooks: 51.5 mm
    If you have 500 springs, could you check these measures, because
    i have some with different lenghts. ( 50.5 mm, 52.5mm) but most
    are 51.5 mm.
    Thanks for the autos
  2. stormer254 Husqvarna
    England
    More than I dare let her know
    Yes!
    Hi Michel, I would be interested and even more interested if they were okay for my 420. Sorry I did not do any measuring last weekend, but I am working 14 hour days at the moment, I will try again on Sunday this weekend
  3. Michel Dufayard Husqvarna
    France
    The steel is named CSH ( in France ?).
  4. WayneL Husqvarna
    Australia
    87 WR400 88 WR125 84 AE500 &13 WR300
    BMW R1200GS and R80G/S PD
    Michael
    I'll measure my 500 springs and let you know what length they are.
  5. Michel Dufayard Husqvarna
    France
    OK thanks ! Do you need some ?
    Cause I plan to order in 1 week.
  6. PEZBerq Husqvarna
    Brisbane, Australia
    390AMX, 430XC, 240WR, 2x510TE, FE501
    Hi Michel
    I measured my spare 16 12 793 01 springs. They vary in length between 51.1 and 51.9 mm. Three were 51.1, two were 51.3, two were 51.5, one at 51.7 and one at 51.9 mm. Majority were below 51.5 mm
    Wire dia = 3.5
    Coil OD = 17.65
    4 active coils like your photo.
    Using my spring sample I suggest the range 51.0 to 52.0 would be quite acceptable. Target length 51.5 mm +/- 0.5 mm. You have some springs that would be outside this range!
    I have also several pig tail design springs used in the later model auto clutch hubs (so called Swiss cheese design!). These are more difficult to measure! I think the pig tail was an improved design over the twin hook spring because it has only one hook bend. Husky introduced it after 1984 but not sure exactly when.
    Good luck with the manufacture!
  7. Michel Dufayard Husqvarna
    France
    Thanks PEZBerq
    51.5 mm lenght seems to be the good measure.
    I'll see the manufacturer next week, for 60-70 springs .
    I have several orders from automans.
    Thanks
  8. ssaulnier Husqvarna
    San Antonio, TX
    I would be interested in springs for the 1981 - 1982 420 AE also, but I think they are a slightly different size from the 430/500 springs. Do you know where I can find a set?
    Thanks
  9. Michel Dufayard Husqvarna
    France
    Ssaulnier , can you check your spring lenght ?
  10. stormer254 Husqvarna
    England
    Yes!
    I have measured my 420 springs tonight, I have 2 spare sets unused, 49.9/ 50.0 long, wire dia 3.37/ 3.34, coil od 18.15/ 17.86, 4 active coils , they look exactly like your photo, there is not a lot of difference from the springs you have. I have measured some used ones from broken sets and they are up to 51.5 long
  11. Michel Dufayard Husqvarna
    France
  12. 310huskyTE Husqvarna
    Melbourne Australia
    2014 FE 350, 2011 Meo.
    67 CR250, 71 400 Cross, 78 CR250
    I have a spare set of springs for my 82 420 I can measure tonight as well if it helps.
  13. WayneL Husqvarna
    Australia
    Michael
    All of my spare springs measure between 50.8 to 51.15 mm.
    I guess if they were longer, you would need to add metal to the back of the shoe to keep the spring taught?
    Ps. I went and re-measured them after reading your measurements Pezberg, lots of variation I guess.
    Wayne
  14. Michel Dufayard Husqvarna
    France
    I've seen the manufacturer yesterday.
    He needs 2 months to do them !!!
    He told me 3 weeks 1 week ago !!!
    Lot of work now and holidays in August.
    The price will be less than 10 € each.
    I asked for a 51 mm lenght.
    The measures will be in 1 mm fork.( 50.5 to 51.5)
  15. stormer254 Husqvarna
    England
    Yes!
    I will be needing a set or two Michel, let me know when you have them please.
  16. Michel Dufayard Husqvarna
    France
    Do you need them for the 500 (51 mm long) or for the 420 ?
  17. stormer254 Husqvarna
    England
    Yes!
    A spare set for my 86 430 which I believe are the same as the 500 and a slightly shorter set for the 420 please.
  18. Michel Dufayard Husqvarna
    France
    I've phoned to the manufacturer today.
    He was in Holiday in August and have now plenty of work.
    Some are made partly. He needs to make a special tool to make the little hook.
    They will be aveliable end of September.
    WayneL, 310huskyTE and husky jim like this.
  19. Michel Dufayard Husqvarna
    France
    I just come back from the spring maker with the springs.
    I've asked that the inner lenght be 51 mm and
    also that some springs are 50 mm ( 420 for stormer 254 ?)
    I've taken some measures which varies.
    I think the best is to match lenghts.
    Measure all springs and put them in different boxes ( 50.8 , 50.9, 51, 51.1, 51.2, 51.3, etc...)
    As you see the little hook is a bit different.
    He also told me to cut the wire if necessary to adjust to the shoes hole.
    The wire is named " corde à piano suédoise" ! ( swedish wire piano).
    husky jim and dartyppyt like this.
  20. stormer254 Husqvarna
    England
    Yes!
    Hopefully they will play a good tune:) Pm me Michel for funds etc.
