Max hours between air filter cleaning
Discussion in 'General (Main)' started by JPinNC, Jun 3, 2010.
  1. JPinNC Husqvarna
    North Carolina
    2009 TXC250
    2009 KTM 300 XC-W
    What is the max number of hours you have ridden between air filter cleaning? I ride strictly off road. This early summer we have had a lot of nice weather, but brief periods of rain almost daily. So the trails have generally been perfect, tacky, no dust. My air filters look just fine. In general my rule of thumb has been to clean the air filter about every 10-12 or so hours of riding. It sure looks like I could go longer in these weather conditions.
  2. noairkerr Husqvarna
    Colton Oregon
    2009 WR 125
    2006 yamaha wr250f 2005 ktm 200 exc
    I just keep an eye on them,if conditions are good ,or you're out front,you get by longer. Also some bikes just seem to get dirty quicker. Cleanings cheap.KP
  3. Dirtdame Administrator
    Rock Springs Wy
    11 WR300,13 WR125,18 FE501
    17 Beta Xtrainer
    I'll ride as long as the filter keeps looking relatively clean. One dusty day out and it's time for a cleaning, or a few months of solo riding or riding when there isn't dust.:excuseme:
  4. chilehusky Husqvarna
    Chile
    On our winter (rain season)i clean my filter only few times. During summer usually one longer ride is enough dirt to clean it. Thats why i always have 2 filter elements. I dont worry about hours, i simply look at it when i park the bike, and if its dirty its time for cleaning.
  5. LawnDartMike Husqvarna
    Salem, OR USA
    I know its overkill but I put a clean one on before each ride. I figure its cheap insurance.
  6. JPinNC Husqvarna
    North Carolina
    2009 TXC250
    2009 KTM 300 XC-W
    Thanks for the replies! Can you tell I am trying to avoid cleaning my filter before riding this weekend?!
  7. jmetteer Husqvarna
    Woodland, WA
    TXC300 CR125 CR144
    WR250F, TRANSALP
    My past changes show a max of about 15 hours in the winter time, it varies from 2 hours to 10 hours... It depends on conditions, I change it out based on how it looks and I have 3 filters so that makes it simple.
    Later,
  8. Coffee CH Owner
    When the choke is no longer needed to start the bike when cold... :lol:
  9. Reddog Husqvarna
    Michigan
    That's my system too:thumbsup:
    JK;). When ever it starts to look dirty I change it.
  10. krieg Husqvarna
    Matthews, NC
    Many in the past
    '12 Triumph Scrambler
    That's funny! I'm not quite that bad, but there's some technical merit to not "over-cleaning". About a year or two ago, I read a pretty compelling technical paper on oiled-foam filters. The gist of the article was that filtration was "optimized" when a certain percentage of the foam cells were partially filled with trapped contaminants... i.e. a dirty filter cleans better! Obviously there is a point when too much is bad (airflow is restricted too much) but the data shown in the article was very clear. A freshly cleaned and oiled filter allowed significantly more particle passage than a partially dirty filter. Now... I only wish I could remember the source and where I found it. It may have even been a bike forum... I just can't remember. :banghead:
  11. Dirtdame Administrator
    Rock Springs Wy
    17 Beta Xtrainer
    I read that about K&N gauze filters, but I think those are too capable of passing dirt most of the time anyway.
  12. Slowpoke Husqvarna
    Southern Ontario
    I clean mine when they are good and dirty(ie. the filter is varying shades of brown/grey/black), regardless of how long it takes.
    I use Belray air filter oil and a layer of grease on the rim. The inside of the filter is always clean, even though the outside may look like it has a layer of dried mud on it.
  13. Fat Tire Flyer Husqvarna
    Canada
    I use Belray to oil my air filters (have three).. At the same time I also Belray oil up a pack of PC Racing Filterskin (sold as a 3 pack).. When the Filterskin is dirty.. You peel off the Filterskin and you still have a clean air filter underneath..
    When the air filter is dirty.. Remove it and then install a clean air filter and clean Filterskin combo.. Once I'm done using all three sets.. Wash the three air filters
    and three Filterskins in kerosene at the same time (once or twice a year)..
  14. JPinNC Husqvarna
    North Carolina
    2009 TXC250
    2009 KTM 300 XC-W
    Thanks again for all the replies. I rode about 3 hours today, so I figure I have about 17 hours on this filter. Again, no dust today. The filter actually still looks good! It is due for an oil change, so I'll clean the filter this time.
    Fat Tire Flyer, I like the Filterskin method. It sure sounds like it would simplify maintenance. Since it decreases the number of filter changes there are less opportunities for me to get crud in the intake system. :applause:
  15. naga Husqvarna
    Reno, Nevada
    TE250. TXC450
    OH! You can clean those? :doh:
    I just keep spraying more No-Toil on mine.
  16. gestion01 Husqvarna
    Montreal
    On my son's 65sx some days I change it 2 times in the same day. 10 minutes in and it has changed color. We have 6 ready in a bag just for him.
    It's all about conditions. On the huskies I use the ktm pre-filter and can go 3-4 rides before it needs changing. Even in wet conditions the filter may need drying. Having more than one ready is best.
  17. JPinNC Husqvarna
    North Carolina
    2009 TXC250
    2009 KTM 300 XC-W
    Which product are you using as a pre-filter?
    http://www.ktmcyclehutt.com/ktm-par...lters-Air-Filter-Accessories&fitment=bigbikes
  18. Darkside Husqvarna
    SF Bay Area
    none left
    beta, ktm, aprilia
  19. Coffee CH Owner
  20. ghte Husqvarna
    Bright, Victoria Australia
    I use a hospital grade air net with motul filter oil as a pre filter during summer. I take it of at the end of the day.and have a clean (ish) filter for the next days ride. Does not seem to make my bike feel starved etc.
