MCCT install tips
Discussion in '610/630' started by djchan, Aug 19, 2009.
  1. djchan Husqvarna
    Maine
    I'm changing out the ACCT for an APE MCCT this evening and wanted tips for the install. Seems I've heard to remove the center bolt/spring so as to preserve the last position on the shaft. When I install the new MCCT do I go back to the same shoulder-to-shoulder distance and work from there? Any other tips?
    Thanks in advance
  2. Nesbocaj Husqvarna
    Just did this a week or so ago. I measured the distance on
    the auto and set the manual the same.
    Some adjust to a lesser distance and adjust in by engine sound.
    Mine is fine.
  3. Xcuvator Husqvarna
    Scholls Oregon
    yes
    If I was going to use the ACCT exposed length, I would remove the ACCT then reinstall so it has to reset itself. Turn the engine over or even start it and run it a little bit. Then remove it and take your measurement.
    That way you know you aren't using a measurement from the adjuster when it has over adjusted itself.
    I think that the ACCT sometimes over adjusts, or jumps a notch during chain whiplash or some other event. If you take your measurement after removing the adjuster, it could be in such a state of over adjustment. If it is, it will be OK, but you could be defeating the idea of the ACCT until the chain stretches or wears in to the tighter adjustment. IMO
  4. Nesbocaj Husqvarna
    Darn good point! I had my bike semi-apart, mid pipe off. So while I was
    there I adjusted mine out just a bit, sounded the same on start-up.
    Also, I wonder how much the chain slacks when hot as apposed to cool?
  5. Xcuvator Husqvarna
    Scholls Oregon
    yes
    I forgot to add that I caught my ACCT doing that very thing.
  6. djchan Husqvarna
    Maine
    Thanks. Sounds like a plan.
  7. restukey Husqvarna
    Bethesda, Md
    I've done around 15k on my current chain with a MCCT. I think the chain likes to be on the tight side. Before I figured that out, I backed out the chain one time after removing the left side cover to inspect. The motor eventually gave some weird misfires.
    Eventually or most likely you're going to have to make an adjustment without the ACCT as a reference. I don't try and get rid of all the noise, not going to happen. You could probably make the adjustment at oil changes if you don't let them go too long.
