Metal Gear brake discs
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by shawbagga, Mar 9, 2018.
  1. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    Dunno if anyone's ever tried them but I thought I'd give them a crack as I needed new discs & they're an Aussie mob. Spoke to them in November as they were out of stock for 125(250/310 4T's) rears & they were just waiting to do another run. They called back mid December saying they were all in stock. All 4 discs delivered for around AU$360 from memory! Just mounted rear up on 125 so will give it a crack over weekend hopefully & see how they fare!
    Pretty much a copy of OEM Braking discs for fronts so look good! Speedo magnet hole & all. Rears slightly different but better looking thàn stock IMHO. Rear for 300 is fixed not a floater(what I wanted!) image.jpg image.jpg
    NCSteve likes this.
  2. ghte Husqvarna
    Bright, Victoria Australia
    Cant wait to hear your learned report Shawbagga.
  3. NCSteve Husqvarna
    Appalachia
    12 WR300 13 WR165
    02 XR250R 00 XR100R
    Me too, though I guess won't get those in the states :cry:
  4. ptkatoomer Husqvarna
    San Diego area
    None
    2020 ktm 300 xc-w, 2020 ktm 500exc
    Wouldn't a floater do a better job of keeping the disc aligned between the pads?
  5. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    I'm sure they'd post stateside & with exchange rate still be cheap for you guys!
  6. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Probably but who(brands) runs them these days? Plus I hated the rattle. They do the floater type plus all associated hardware!
  7. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Well did 160km of single track on Sunday & pleased to report rear disc was great. Good feel & power(after few minutes of bedding in). No gouging, bluing or wear(a lot of rear brake sliding into switchbacks & downhills).
    Will put front one on this week & see how that fares as my oem disc(175ish hours on 125) is like a bit of alfoil thickness wise!
  8. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Put the front disc on the other night before a ride along with new pads & Belray super dot 4 fluid. Also greased caliper pins.
    Brakes work fantastically, just like new again. Ya sort of forget how much performance you lose gradually after a while. The old front disc was that skinny you could easily warp/twist it by hand. Probably only 2mm thickness left at a guess! Like alfoil
    Oldscool, Huskynoobee and NCSteve like this.
