microsquirt on 09 sm510
Discussion in 'EFI/carb' started by husqdeeznutz, Jan 25, 2010.
  1. husqdeeznutz Husqvarna
    CALI
    I was thinking about taking the stock ecu and using microsquirt. Does anyone know how the returnless system works? It looks like the fuel pump sees a constant voltage so does that mean it works by using the injectors? Or is there something in the throttle body I'm missing.
  2. husqdeeznutz Husqvarna
    CALI
    Nvm I think the regulation is done in the pump itself...that makes things easy
  3. seymore Husqvarna
    Boise, ID
    On the inside of the pump assembly mounting plate casting there is a spring loaded bypass valve that relieves excess fuel pressure above 40psi.
    How well the the pressure is regulated and how much is varies from bike to bike I don't think is well known.
    I may be possible that the microsquirt has a analog input that could be used to monitor fuel pressure and compensate injector timing.
    Doing a microsquirt conversion sure would be an interesting and likely time consuming project. You would certainly be a lot smarter or insane in the end.:D
