Mikuni Jetting for 1974 CR 125 Help
Discussion in 'Vintage/Left Kickers' started by mtbrider, Mar 26, 2011.
  1. mtbrider Husqvarna
    Australia
    The Mikuni is finally on with my home made remote choke and it is running and idling well. Current specs are:
    Mikuni VM 32
    main 4 / 042 200
    pilot 35
    needle jet 159 Q6
    jet needle 6DP17
    throttle valve VM 34 / 110 3
    air jet BS30 97 2.0
    needle valve VM 34 / 39 3.3
    Seems fine up in the rev range however is bogging down badly from take off. The needle has a very aggressive taper so it seems to be dumping too much fuel in when you throttle on drowning the plug.
    Tried a 6F76 of a 250 but same problem. Any ideas on size to stop this problem. PS I am in Australia.
  2. auto Husqvarna
    NJ,USA
    too many
    Have you ever rode this 125 before putting the Mikuni on?How did it run before?
