Mikuni power jet carbies
Discussion in 'Vintage/Left Kickers' started by watto450, Jul 30, 2015.
  1. watto450 Husqvarna
    Australia
    1965 250, 1978 390 Auto, 1983 510 TX
    Anyone tried this set-up on a VM round slide....?? I read the blurb.. it say to reduce the main jet by 25% and then install the power jet the size of the reduction in the main jet.. so for a 420 main jet.. install a 310 (ish) main and then a 100-110 power jet...claims to provide more mid-ramge and up top also.. anyone tried one in a "vintage" application??
  2. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    i have heard they work well once dialed in, is it externally adjustable?
    lectrons use this type of setup sorta, only it is externally adjustable. turn a screw, adjust the "main" circuit
  3. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    what exactly is the "power Jet" referring to?
    they have a main jet, jet needle and needle yet on that circuit
    the main jet is only for when you get past 1/2 throttle
  4. 454x Husqvarna
    Dunnigan,Ca.
    2012 CR165 w/36mm lectron.
    I THINK HE IS TALKING ABOUT THE tHUNDER pRODUCTS DIAL A JET. SORRY FOR THE CAPS.
  5. suprize Husqvarna
    Bendigo, Australia
    ktm 300
    Are you thinking 510?
  6. Motosportz CH Sponsor
  7. Kartwheel68 Husqvarna
    Newnan, Georgia
    The Mikuni power jet kit is indeed like the Lectron. It adds another vacuum activated circuit above the main jet that richens the fuel mixture at the very top end. This allows the main jet to cover the mid range 1/2 to 4/5ths area which allows it to be leaner, the power jet controls wide open.
    watto450 likes this.
