Missing engine oil, broken oil pump?
Discussion in '610/630' started by Ketek, Mar 16, 2015.
  1. Ketek Husqvarna
    Germany
    Sup guys, long time no read.
    I've got a little problem here:
    I wanted to change my engine oil today, pulled the drain plug, but only 250ml oil came out :confused:
    So I wondered where the rest could be and opened the right engine cover. And there it was! I then refilled the engine with 2 litres of fresh oil, started it up and let it run for 10 minutes. I then drained the engine once more and again only some 250-ish ml came out.
    So I wondered wether the oil pump worked at all. I removed the hose that connects the pump to the cylinder head and let the engine crank over. Only air was coming out of the hose. I then removed the oil pump cover.. and again only air was coming out when cranking over..
    Does anybody have any idea what's the problem here? The pump itself seems to work, but it doesn't move oil :confused::confused:
  2. RDTCU Husqvarna
    '11 630SMS
    Clogged right side filter screen? Blown pump seal? clogged drain passage in the sump?
  3. Xcuvator Husqvarna
    Scholls Oregon
    yes
    There are two drain plugs, one of which only drains a small amount of oil.
    Tinken likes this.
  4. RDTCU Husqvarna
    '11 630SMS
    I gave him at least that much credit, haha....
    Yeah, you have to pull both drain plugs.
  5. DYNOBOB Husqvarna
    Also, bike has to stand upright for a minute or two before oil finds it's level.
  6. Theo Husqvarna
    Lombardy, Italy
    SM 610 I.E.
    2001 YZ250
  7. EricV Husqvarna
    Also- it takes quite a bit of turning the engine over to finally see oil coming out of the upper banjo fitting at the cylinder.
  8. Ketek Husqvarna
    Germany
    God I feel stupid now. I've had the bike sitting in the garage for like 2 years and haven't touched it since. Thus I totally forgot that this engine has 2 drain plugs. And since the bike was on the stand I couldn't see the second plug. :rolleyes:
    Also thanks Theo, I reassembled the pump, this did the trick.
    I'll ride to the next beer garden now haha :cheers: Thanks guys :thumbsup:
    Theo likes this.
