ML Frames
Discussion in 'Vintage/Left Kickers' started by redman, Mar 2, 2023.
  1. redman Husqvarna
    Pa
    77 360 automatic
    ec200 Gas Gas
    I'm looking to buy, what I believe, is a "76" 360 (basket case). It has a ML frame number. From what I found it looks like the WR and CR used a ML frame number. Am I correct in my findings? Did the WR and CR use the same frame in "76" and "77"?
    I think the only way to tell the difference is by the engine prefix ...correct?
    Thank you, John
  2. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    70,71 360 8s 72,74 450 73 360 73 250
    66 Triumph Trophy 99 ZRX1100
    Good luck John
  3. motomwo Husqvarna
    Imbler Oregon
    Many vintage big bore and automatics
    1978 frames are also in the ML series. And the 78 frames are different than the 75-77 frames. Can you include a picture? How about the frame number?
    Marty
    DeathFromAbove likes this.
  4. DeathFromAbove My Cat Says AREAR!
    North New Jersey
    That screenshor is of the 360cc section sorry did not include that earlier
  5. redman Husqvarna
    Pa
    77 360 automatic
    ec200 Gas Gas
    Marty,
    I do not have the bike yet, so no picture, but the frame number is ML10237.It looks to me like a "76"?
    DFA, That's the same info I had found.
    Thank you both, John
  6. redman Husqvarna
    Pa
    77 360 automatic
    ec200 Gas Gas
    Also, the fella I'm getting this from also has 2, 250's that the frame numbers are only 7 digits apart. I'm guessing they where pretty close on the assembly line.
  7. motomwo Husqvarna
    Imbler Oregon
    Yes that is a 1976 ML serial number for the 250's. Cool to find two with serial number that close.
    Marty
