MME clutch lever is out!
Discussion in '610/630' started by Travis Shrey, Nov 30, 2011.
  1. Travis Shrey Husqvarna
    Lon Gisland
    Just got an email from Steve at Midwest Mountain. Their two finger easy pull clutch lever for the 630 is now available. His email is steve.pohl@midwestme.com...
    Travis,
    I have them in stock just have not updated the website yet. You can send a paypal payment to my email address in the mean time. The clutch lever is $65. A matching brake lever is $50. USPS first class mail is $3.60. International USPS Priority mail is $15.
    Steve
    jtemple likes this.
  2. SilverBullet Husqvarna
    Harmaston, TX
    2011 TE630
    My clutch pull is already like slicing butter with an easy two finger pull. Your bike isn't? Very nice looking lever though.
    _
  3. Travis Shrey Husqvarna
    Lon Gisland
    It is smooth, no doubt. This lever is short enough that with two fingers you don't pull the lever to smash your ring finger and with the new pivot point clutch feathering is a one finger job.
    I get arm pump riding tight single track even with a 14t cs. Maybe I'm just a wuss.
  4. SilverBullet Husqvarna
    Harmaston, TX
    2011 TE630
    I don't wear a ring so that helps for me. When I first started two fingering I thought my fingers could get smashed but not really possible. Can't pull in lever hard enough with two fingers to hurt. I also would not ride like this without barkbusters in the woods. Otherwise you could really hurt your fingers if you smacked a tree.
    _
  5. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    2013 Kawasaki ZX-14R
    Thanks! I've been looking for some shorty levers.
  6. Travis Shrey Husqvarna
    Lon Gisland
    I've finally got the lever installed and it is sweet. Clutching is a one finger exercise now. Only downside is that the clutch safety switch pin isn't contacted when the lever is pulled. For now I shorted it out; I'll add a glob of JB Weld to the lever so that it contacts the pin when the lever is pulled. I'm guessing I'm going to have the same issue with the brake lever when I install that. Lever is also much broader (vertically) so the load is spread out over a larger part of your finger.
  7. LRPct Husqvarna
    NW connecticut
    all that and no pics???
    Ketek likes this.
  8. BiG DoM Husqvarna
    Will these work on the 610 as well? Would also like pics.:thumbsup:
  9. Travis Shrey Husqvarna
    Lon Gisland
    I was too excited to get them on the bike and ride! I'll snap some today and upload.
    Provided you have the same clutch lever as a 630 yes :) MME actually only advertises them for KTM's, he didn't realize that we have the same Magura clutch setup. I'll put a pic of a stock 630 lever up - if your 610 lever looks the same I would say they would fit.
  10. jtemple Husqvarna
    Papillion, NE
    2011 TE630
    The 610 clutch is cable actuated. Probably not the same part.
  11. Kevin2735 Husqvarna
    Summerland, CA
  12. Travis Shrey Husqvarna
    Lon Gisland
    Oh, yeah this is only for the Magura juice clutch. Pics are coming.
  13. BiG DoM Husqvarna
    Who makes two fingers for the 610??
  14. Travis Shrey Husqvarna
    Lon Gisland
    You can see the pin down inside the lever pivot cage - when you pull in the clutch this pin has to be pushed back a little in order to close the clutch safety circuit. You can also see the large adjustment screw on the lever - I have backed mine out a bit so that the lever sits closer to the bar and isn't so much of a reach.
