250-500cc model identification
Discussion in '2 Stroke' started by windy851, May 4, 2015.
  1. windy851 Husqvarna
    cr250
    BSA A10, Triumph 500, Laverda 750, r
    Hi
    just been working on what Im told is a 1992 CR 250
    tried to check it out on line but frame number is DGM53255 OM 5A 000281
    cant seem to get a definitive year/model with the DGM apart from a few posts on line.
    does anyone know a site which would show the same sort of number?
  2. windy851 Husqvarna
    cr250
    been a while but need to register this bike to get title.
    still looking for help regarding any more info , thinking now its a WR250 which has been fitted with 297 top end.
    no luck looking with a DGM frame number, just assuming its a Husky but could it be a Cagiva number instead of Husky
  3. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
  4. 2premo Husqvarna
    Northern NV
    do you have any pics?
    justintendo likes this.
  5. justintendo klotz super techniplate junkie
    mercer, pa/northwest pa
    99 kawasaki zrx 1100
    have you figured out the other issues you had going on?
  6. juicypips Husqvarna
    gloucestershire
    wr 360. 2002
    The 297 may just be a casting mark as the 360's are stamped on the head with 266. The cc should be on the left hand side of the reed block.
    I use the term should very loosly it may be on the right or ground off.
  7. rancher1 Husqvarna
    WA
    How about a picture, it would sure help us help you.
  8. windy851 Husqvarna
    cr250
    sorry for delay been in France have put a pic up.
    still cant get a decent spark and its been left as is for now.
  9. 2premo Husqvarna
    Northern NV
    the picture is definitely of a 92, they had an aluminum subframe, swingarm mounted kick stand, mid height pipe and Showa suspension
    the numbers are odd but it is definitely a 92
  10. rancher1 Husqvarna
    WA
    I am gonna say it is a 93, the adjustable fork preload caps were not on the 92 and it has white fork guards another sign of the 93.
  11. 2premo Husqvarna
    Northern NV
    ahh, but look at the swingarm, oddly my 92 had adjustable caps too,
    guess the caps might have been a popular upgrade in 93?
  12. rancher1 Husqvarna
    WA
    Did the swingarm change in 93 or 94 ???
  13. 2premo Husqvarna
    Northern NV
    the swing arm went from square edged to rounded in 93 when the kickstand moved to the frame
  14. 2premo Husqvarna
    Northern NV
    i had a 92 and 93 a while back
    replaced the 92 with a 98 and 99
    sold the 98 to my brothe
    been down the 360 road
    need to look at an 02 next? :banana:
  15. windy851 Husqvarna
    cr250
    hopefully got the title coming by the end of the month. still cant get a DGM frame number..
    also Motoplat parts are few and far between or expensive. used part 60 euro +24 p&p from Italy
  16. justintendo klotz super techniplate junkie
    the mini 4 motoplat is unusual and very hard to find. earlier motoplats are very common, rebuildable and semi-reliable. sadly they will not fit the italian 2 stroke
  17. windy851 Husqvarna
    cr250
    yes I find the 4 stroke coils with 2 terminals, a large and a small. the mini is hard to find.
  18. Dauer Husqvarna
    Western NC
    1992 WXC 360
    '89 Yamaha TDR250, '01 ATK 605
    I'm in the same boat as you. Been actively (and passively for that matter) searching for a motoplat "mini 4" stator for my '92 360 for some time with no progress. Sorry to say that I have been feeling discouraged and as a result the task was put on the back burner, I plan to get back on the horse over the winter when the weather has soured.
  19. justintendo klotz super techniplate junkie
    would it be possible to switch the crankpin to the later 250/360 one? that would open up a huge amount of available ignitions. or is the bolt pattern different for the backing plate? my 95 360 will use the same ignition used up until recently
    juicypips likes this.
  20. windy851 Husqvarna
    cr250
