Modern Hub on a Nordisk Rim
Discussion in 'Vintage/Left Kickers' started by husky jim, Aug 21, 2020.
  1. husky jim Husqvarna
    USA
    14 WR300, 87 430wr, 86 430ae, Tr650
    I was wondering if anyone has experimented with using a modern 2010-13 Husky hub on a vintage Nordik rim. I was wanting to keep an original style rim on my Ae with the new front end.
    Thanks
  2. rancher1 Husqvarna
    WA
    If anyone could lace it up it would be Buchanan’s.
  3. 2premo Husqvarna
    Northern NV
    Sherco 300, 2002 KTM 380EXC
    my memory keeps going back to a thread on this, but can't remember what started it or how far back it was
    but it is in the older threads
  4. husky jim Husqvarna
    USA
    Thanks, I looked but didn't go way back. Been busy working on the SM430. Finally got it ready for tires.
  5. husky jim Husqvarna
    USA
    Thanks, I'll check them out.
  6. Picklito Husqvarna
    Washington
    430, 430, 430, ,400, 175
    KTM250xc, KTM500mx, KTM440exc
    I think you could do it. Use the spokes that match the hub, use a standard 4-cross pattern. Once centered and trued, check whether the spokes poke up past the end of the nipples then grind them flat if they do.
  7. husky jim Husqvarna
    USA
    I was kinda thinking the same thing. I'm going to unlace a spare 86 wheel try and use the spokes and the rim. I measured the spokes and the hubs. They do seem to be the same if not extremely close
  8. 87husky500xc Husqvarna
    Dayton NV
    2020 tx300i and a few vintage bikes
    77 honda xr-75..
    Can’t say for sure with a new husky hub but tried to lace a 05 Ktm hub into an 85 nordisk and the angle that the spoke went through the rim was slight off. The holes in the rim would have to be re-drilled I believe. I think the issue was that the bolt circle for the spokes was a larger diameter than the husky hub which changed the spoke angle slightly. Also nipple diameter could be different as well as the countersink angle for the nipples. Look forward to seeing if it works out for ya though!
