250-500cc Modifying stock silencer?
Discussion in '2 Stroke' started by wrtimmy, Mar 12, 2016.
  1. wrtimmy Husqvarna
    2014 WR300
    Has anyone played around with opening up a '14 WR300 silencer?
    I'm in Australia and the bike is road registered, so I'm guessing there some compliance gear in the stock pipe to pass road rego requirements.
    Is it possible to drill out some rivets and gut the internals? I've heard there may be a washer welded in to restrict it.
    Thanks!
  2. shawbagga Husqvarna
    Eaton, Western Australia
    None
    2018 Gasgas XC250
    Silencer is straight through. Can be shortened.
    Pipe is also straight through unless u have the euro/ADR POS pipe on which is heavily restricted. I doubt it though as your bike wouldn't pull the skin off a rice puddin with that pipe on!
    Did you get 2 pipes(expansion chambers) with the bike?
  3. Brian Scott Husqvarna
    Bainbridge Island, Washington State
    '11 WR 300
    '01 CR 500R
    This is what it looks like when taken apart and cleaned. You have to drill out the 4 rivets on the core to pull out the core. You don't have to pull the end cap out to repack; only the front piece. I replaced the 4 rivets w/allen screws to make repacking easier. You'll need to apply heat to the ends of the alum. can to get the end pieces out. Be careful during reassembly as it's easy to pinch the o-rings on the end pieces. Again, heat the can so the end pieces slide in easier.
  4. shawbagga Husqvarna
    None
    2018 Gasgas XC250
    Yeah in Aus we jus get a straight thru silence with no SA. Unless u somehow got a US version Timmy?
    wrtimmy likes this.
  5. wrtimmy Husqvarna
    2014 WR300
    Cheers for the comments everyone!
    It's definitely an Aus delivered bike, got no problems keeping up with 450s on the trail so mustn't be the euro expansion chamber!
    It was only through Google'ing I saw the honeycomb in the pipe and washer welded into the silencer which brought about the question.
    Just the one, but wouldn't have been surprised if the silencer was restricted. But it doesn't seem like it!
    Cheers everyone
