Molikote HSC equivilent or where to buy?
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by Grump, Dec 17, 2008.
  1. Grump Husqvarna
    Florida
    Is Molikote HSC the same as anti-seize or something else with a different name? Or where is the best place to get some Molikote HSC and any other specified maintenance items for my Husky. I guess the dealer huh?
  2. scoobywrx05 Husqvarna
    Warren PA
    The only molikote I've ever heard of or used is a spray that you coat rifle bullets with,probably not the same stuff, I'll have to go and read the can.
  3. rajobigguy Administrator
    So.Cal.
    If you are using it for bolts outside of the engine then most any antisieze will work but if you are using it for anything inside the engine or on any bearings then you need something similar to molikote/molycoat. Moylycoat is a petroleum based lube with molylidium disulfide and can be purchased at most industrial supply shops like Grainger, McMster Carr or Applied Industrial.:cheers:
  4. Grump Husqvarna
    Florida
    Ok, Thanks for the info. I was just reading the repair manual and they recommended using it so I figured I would get my maintenance stuff ready for future reference. I have moly lubes but will do a little more research to see if they are different before I substitute them...
