250-500cc More Carb Questions
Discussion in '2 Stroke' started by david gross, Oct 3, 2014.
  1. david gross Husqvarna
    New Zealand
    2008 WR250 1984 WR250
    1979 GS750
    Hi All, I have acquired a 38mm Air striker for my 09 WR250 it came with a JD jet kit. Its running Blue needle 2nd clip from top. 175 main 45 pilot air-screw 3 turns out.
    I am having a night mare trying to set this up. First thing is there a definitive way to set the float height . Have tryed the 60 Deg 16mm to top of float then told that no good as it still compresses the valve ? .
    Were i ride is approx 0/600m above sea level bike has only 2Hrs on new piston rings and reed petals, Cleaned out and checked P/V when i did piston.
    Any a all help gratefully received.
    Many Thanks Dave
  2. rockdancer Husqvarna
    Sunshine Coast, Australia
    2013 WR125, 2019 FE350
    check u tube for videos on carb height check
    Id start with needle in the middle - air screw at 1.5 out
    check pilot ( may be rich )
    then check mid - needle
    and then main
    FWIW my 125 had a lean bog with blue needles on 2
  3. steadydirt Husqvarna
    Ontario
    2007 2002 wr 250 1994 wxe 250
    Rockdancer- quick question [small hijack beg pardon] what needle did you prefer? I am messing with a 2006wr 125 and getting closer tmx carb'1200 ft/60 degrees- still a little lean off the slide onto the needle Ever try another slide?
  4. david gross Husqvarna
    New Zealand
    1979 GS750
    Thanks for the input, will check out u tube.
  5. rockdancer Husqvarna
    I used standard needle 60 ? and slide on old tmx. Worked fine for me. Only seen guys going for bigger slide
    Sure it's lean ? Hard to tell as rich can feel like a bog
    steadydirt likes this.
