125-200cc More power(electrical)needed
Discussion in '2 Stroke' started by bicyclephil, Jul 24, 2017.
  1. bicyclephil Husqvarna
    TE 300
    KTM 450 XCF
    2016 TE 300
    44-1
    Lectron
    Engine ice
    Trail Tech digi fan set at 180f
    Garmin Montana hard wired to battery
    Stock headlight(rarely used)
    Bike runs great, a bit of spooge, no boil overs.
    Most of my riding is intermediate-expert singletrack trail.
    The other day I rode Foresthill tr. 6, approx 16mi loop. We did it twice. About 90f out, tons of dust, and yes, loads of fun!
    *Midway through loop 2 my battery lost enough power that the starter output was weakened, unable to start a warm bike. My bike normally starts right up, cold or hot.
    **The fan, set at 180, seemed to run a lot, and would kick on for 30sec-1min after shutting bike.
    ***So I'm thinking the fan tried to kill the battery
    Next day I check static voltage, 12.4, charge for a while, battery comes up to 13.6.
    After disconnecting charger the voltage slacks off(4-5min) to about 13.3
    No simple answers I'm sure.
    I will check charging system soon.
    Can you guys comment on possible solutions such as:
    Rewound stator for more power(Trail tech, Ricky, BD)
    Stronger battery, ?Lithium?
    Reset fan temp, lower/higher?
    thanks,
    Phil
