Timberline
I took my new-to-me TE630 to a local Husky dealer for some diagnostic issues with starting; turns out it was old fuel - my bad.
Anyway the tech said it had one old fault code that had been cleared. I asked if he's using ibeat and he said they use MOSS and HST which I read a little about elsewhere here on CafeHusky.
He said he's showing no new updates for the ECU and said if he reflashed it, then it would just return to it's current state settings. When I asked if the air/fuel had been adjusted for the Leo Vince pipe and EHS airbox mod he said he didn't think HST would tell him that info, but that the ECU should adjust for it automatically. He did say that these are way too lean stock but that the ECU should should "learn" that it's getting more air in/out and up the fuel mixture accordingly.
This sounds odd to me after reading so much (which is new to me) about tweaking with ibeat / JD tuner / PowerCommander.
Is the lack of fuel/air mix reporting a known limitation of the HST / MOSS software?
Anyway the tech said it had one old fault code that had been cleared. I asked if he's using ibeat and he said they use MOSS and HST which I read a little about elsewhere here on CafeHusky.He said he's showing no new updates for the ECU and said if he reflashed it, then it would just return to it's current state settings. When I asked if the air/fuel had been adjusted for the Leo Vince pipe and EHS airbox mod he said he didn't think HST would tell him that info, but that the ECU should adjust for it automatically. He did say that these are way too lean stock but that the ECU should should "learn" that it's getting more air in/out and up the fuel mixture accordingly.
