Motion Pro Collar Nut Wrench on Sachs Shock?
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by NothingClever, Apr 21, 2009.
  1. Does anybody know if the standard Motion Pro collar nut wrench works on the Sachs rear shock collar nuts?
    I HATE using a brass drift to tighten the aluminum collar nuts.
  2. dfeckel Husqvarna
    Medford, NJ
    I have one of those, and it works great if you flip up the subframe or take the shock off. No way it's fitting in there with everything in place.
  3. Thanks for the reply.
    Unfortunately the subframe on the '06 TE610 can't be flipped up like on many other bikes.
    And you're right, it's a tight fit in there.
  4. Did some research.....
    RaceTech makes a tool for this. It's essentially a screwdriver with a dulled tip and bent about 1/3 of the way up from the tip.
