Ordered a Motorsportz damper,front disc guard & trailtech vapour speedo from Kelly last week 6th May. Couldn't believe when it arrived yesterday the 12th, all the way from Vancouver U.S.A to Venus Bay, Victoria, Australia in 6 days! So not very happy that Kelly has barely given me enough time to strip the bike to put my new goodies on! The damper is a work of art! Thanks Kelly! Just a few questions on the trail tech, my bike is a T.E 250 2010 model. Can I use existing speed sensor with the trailtech? What do I program PPR to .5, 1.0 or 2.0? Also the parameters for the 2 temp settings & the 2 settings for RPM shift & overshift? Grant.
My dealer fashioned another bracket for the speed sensor on my Beta 350 RS. I think there is some intereference using the same signal for both the stock computer and the Trailtech. The sensor holder looked a lot like the piece that holds the turn signal indicator light, a z-shaped piece. Both speedo units work on my Beta and are about 2 mph different at most.
thanks and thank YOU. I know via your PM to me you already sorted this but yes you can ether splice intot he stock wire or replace it wiht the one provided, will screw right in the caliper leg like stock.
Thanks Kelly, just reading in instructions re: Program Pulse Per Revolution it says this setting is critical! Is it? Do you know what I should set mine at? Thanks. Grant Was just thinking it may be a silly Question, should it be set at 1 for 1 revolution of the wheel? Grant.
