Motosprtz Stabiliser for 510 TXC
Discussion in '4 Stroke' started by Sandgroper, Sep 12, 2009.
  1. Sandgroper Husqvarna
    Dubai
    Well just ordered my first non GPR Stabiliser and am banging for it to arrive, fit and try it out.
    I ordered the Underbar version due to my height to raise the bars.
    Can I fit it myself? if so are there any tricks to fitting it and setting it up?
    Note I dont have a torque wrench for the tripple clamp bolts so dont want to overtighten anything..
  2. Sandgroper Husqvarna
    Dubai
    Fitted the little thing. Piece of cake.
    FYI, you need to grind 1cm off from the edge of the 2 bottom bolt washers as you cant put them on
    otherwise.
  3. Coffee CH Owner
    Thanks for taking the time and letting us know how the fitment went :thumbsup:
  4. Motosportz CH Sponsor
    Nice. Yep it is a real EZ install. I have not seen an issue with interference issues with the bolts?
  5. Sandgroper Husqvarna
    Dubai
    My setup is the same except that I retained the two small factory spacers to raise the bar height. To do this I replaced the factory bolts with 1inch longer units. Works well so far. When I received mine in the post it had oil all around the base which appeard to have leaked out of the unit. I cleaned it and so far it hasnt come back.
    Last thing I want with 100% of my riding in the dunes.
  6. Motosportz CH Sponsor
    Not to fear, it is assembly lube. It will be gone after a few washes.
