Moutning a Trail Tech X2
Discussion in 'Common Items on Husqvarnas: Tires/tubes/grips/etc' started by PC., Apr 2, 2009.
  1. PC. Husqvarna
    Beaverton, OR
    CR165 & CR144
    KTM500
    What needs to be done to the fender to mount this bad boy?
    The instructions say to drill 2 holes into the fender for the pins to drop into, but Husky's have that rib on the top of the front fender. Any suggestions? Or pics please?
    Thanks!
  2. Motosportz CH Sponsor
    I see you picked it up. :thumbsup:
    Remove the fender brace, it is not needed and allows you to mount it with the plate with pins. If you try to mount it with the fender brace it sits up to high and interferes with the brake hose. i have run mine on my 450 without the brace, works fine no fender flop. :thumbsup:
  3. PC. Husqvarna
    Beaverton, OR
    CR165 & CR144
    KTM500
    Yep, I got it.
    Thank you!
    And thanks for the insight. I never realized you did not have the fender brace on your 450.
    I should have it in business later today. Just need to build myself a wiring harness.....
    Question:
    Are people running both the high and low beams simultaneously or just the high beam solo? Can the WR handle the 70W combined!?
