multi-bike steering damper?
Discussion in '610/630' started by 04asphalt, Aug 2, 2009.
  1. 04asphalt Husqvarna
    SW Michigan
    I would like to add a steering damper but to justify the cost I need to find one that would fit my 610 and a 03 ktmexc. I know nothing of SS, is there such a unit?
  2. Creeper Husqvarna
    Ravensdale, WA.
    Most all brands of rotary steering damper are a damper unit, and a mounting kit. Motosportz, Scott's etc.
    It's the mounting kit that makes it specific to a bike. One damper assembly, two mounting kits and you're good to go.
    Many bikes/kits utilize some of the same parts... I mean, there just aren't that many variables.
    For example, the Scott's set-up on my Sherco is comprised of a modified KTM clamp-on post mount and a Suzuki top clamp.
    Call Kelly at Motosportz... he'll sell you what you need to make it all work.
    C
  3. 04asphalt Husqvarna
    SW Michigan
    so you think if I get a used Scotts for the KTM I could buy some mounts from Kelly to make it work on the Husky?
  4. Motosportz CH Sponsor
    Nope, totally different mounting system.
    Kelly
  5. 04asphalt Husqvarna
    SW Michigan
    no way to mod. yours to work on the KTM then:banghead:
    side note: just mounted one of your front axle nuts:thumbsup:
    I hated that allen thing that came stock:censored:
  6. kwhusky Husqvarna
    key west
    610sm with scotts had to make costom pin. Friend has ktm 625 with scotts with weld on pin
  7. 04asphalt Husqvarna
    SW Michigan
    dose the bolt holding your go into the frame or is all the force on the plastic tank:confused:
  8. NOTsoHUSKY Husqvarna
    Vacaville, Ca
    That is the bolt that holds the tank to the frame.
  9. Motosportz CH Sponsor
    IMHO that is not a good way to do that. Structurally it is inadequate and could lead to binding and loss of control. The bolt is not large enough and the platform is relying on a plastic tank and and moving platform.
    there is a lot of force on the pin and the right mounting kit for the bike is mandatory. Get 2 kits and one damper.
